Populating a drop down box based on another drop down box selection
May 10, 2012 5:10 AM
Good day all;
On a form I am designing I have 2 drop down menus labeled, directorate and division.
What I would like to do is when the user selects a directorate, the division drop down is only populated with a list of divisions that belong to the selected directorate.
I am sure I have seen this question asked before, but, I am at a loss to find it…..
Thanks All
Chomp
    May 10, 2012 7:37 AM   in reply to The Chomp
    Here is a sample that can give idea on how to do this..
    https://acrobat.com/#d=CpmL3cuLdnNPeJ6Vc0IhdQ
    Srini
    May 10, 2012 9:51 AM   in reply to The Chomp
    I find it easier to do with a switch() statement and hand code it but if you have a lot of data doing some sort of loop through an array might be easier.
    Below is just a small snip of quite a long list I have in one form. Using xfa.event.newText to get immediate response from the dropdown.
    //on the Change event
    var selection = this.boundItem(xfa.event.newText);
    Desc.clearItems(); //Desc is the target dropdown
    Desc.rawValue = "";
    //above line needed to clear the displayed value in the next dropdown, clearItems() just clears the list.
    switch (selection)
      case "AE":
           Desc.addItem("DF");
           Desc.addItem("FR");
           Desc.addItem("MS");
           Desc.addItem("PC");
      break;
      case "AN":
           Desc.addItem("BI");
           Desc.addItem("FI");
           Desc.addItem("GE");
           Desc.addItem("OT");
           Desc.addItem("ZO");
      break;
    May 10, 2012 9:52 AM   in reply to Jono Moore
    Anybody else lost the ability to get at the advanced formatting (setting font family, etc.)? Can't seem to find where it's gone...
    Nov 2, 2013 7:27 PM   in reply to Jono Moore
    I have copied and pasted this exactly as it is here, I have named my target field DESC and I can't get it to work. I have pasted it into a change event on the first drop down box and then I tried it on the target drop down box. Can you please tell me what I am missing? I have read heaps of posts and they all say to do this differently, I am very confused.
    Nov 5, 2013 11:52 AM   in reply to embroideryallsorts
    The code goes on the first drop down. You have to make sure the values match, in my code the "AE" and "AN" are possible selections in the dropdown, so make sure you are using matching your own dropdown selections. If you've assigned values to the dropdown selections then you would use those instead.
    Nov 5, 2013 12:25 PM   in reply to Jono Moore
    Thanks Jono, I did eventually get that to work using your code from a different post. not sure what the difference was now because I have read so many different posts and I am now very confused.
