I'm using the Overlay creator panel to build a vertical scrolling text panel on a page. As I am saving the folio as a PDF the text within the scrolling (pan) container looks different to the non scrolling text columns. I assume this is because the pan function is converted to PNG or JPG and not built as PDF. Is there a way to build scrolling text panels and retain the sharp scalable PDF text? The only solution I can see is to build the folio as a PNG which withh mean larger file sizes. Help!
You're correct, the text inside the scrolling container is getting rasterized at folio creation time, whereas the rest of the text is getting rendered at display time by the PDF engine on the device. This will result in slight differences in appearance on the device, however if you are creating your folios correctly it shouldn't be a sharpness difference.
Are you trying to create content for the new iPad? If so, make sure you are creating your folio in folio builder at 2048x1536. When you add the InDesign document as a PDF article to a folio that size we will rasterize the scrollable frame content at a resolution high enough to look sharp on the new iPad.
Neil
Not so bothered about using the zoom functionality, but the type needs to look the same at standard sized viewing. I will have to save as PNG I guess. It will be interesting to see if this still happens with folios set up for the new iPad. If it does, then designers won't be ale to use scrolling as part of a pdf formatted app, as it looks bad.
