Hi
i did notice a lag (almostac ceptable, passable) using the brush tool , painting black and white on the maskes
i tried different video card from nvidia to ati , but did not find a real solution
the only solution is set the opengl off or set to basic
did you notice the same issue?
i did update all the drivers
thanks
The Smudge Tool seems slow in Photoshop CS6 because of an apparent bug where the code acts as though it has a zero or near-zero brush spacing and loops excessively, but I hadn't really noticed that normal brushing operations with the plain Brush Tool have a noticable lag or are particularly slow. However, I didn't do objective measurements before...
A while back I posted a thread on Ps Performance, in which I timed some operations done in Photoshop CS5. One of the operations (step 3) was to brush across a particular sized image with a particular sized brush. Since you brought this up, I just re-characterized both Photoshop CS5 and CS6 on my system as it currently is here with the same brush operations...
>3. Strokes with a round, soft brush with spacing at 10%
When the two applications were run one after the other, Photoshop CS6 64 bit did seem slightly slower to me, yet seemed to make more accurate strokes, as though the event queue was deeper, where it was overflowing and causing straight line strokes in Photoshop CS5.
Dragging a big 2500 pixel brush from corner to corner in a 10000 x 8000 x 16 bits/channel image took 5.6 seconds to catch up in Photoshop CS6, and 3.0 seconds in Photoshop CS5, so this seems to confirm that Ps CS6 is a bit slower with a standard brush. But interestingly the deeper queue and better stroke tracking definitely make it more usable in Photoshop CS6. If you're willing to wait for it to catch up, you can paint smooth curves freehand even with a 2500 pixel brush in CS6.
Interestingly, with the Mixer Brush, the same exercise with a 300 pixel bristle brush on default settings seemed to place Photoshop CS5 and CS6 on just about an equal footing. Performance seemed about the same, or maybe even slightly faster in Photoshop CS6, and again the brush strokes track mouse movement more truly and completely in Photoshop CS6, making the Mixer Brush definitely more usable.
-Noel
If you have an adequate video card there should be no lag. With CS6 some changes were made so now some of the functions rely on a new Mecury graphics engine. This may take a little more horsepower and latest drivers.
From a CS6 posting
Tested video cards for Photoshop CS6
Adobe tested the following video cards before the release of Photoshop CS6. This document lists the video card by series. The minimum amount of RAM supported on video cards for Photoshop CS6 is 256 MB.
Note: Adobe tested laptop and desktop versions of the following cards. Be sure to download the latest driver for your specific model. (Laptop and desktop versions have slightly different names.)
nVidia GeForce 8000, 9000, 100, 200, 300, 400, 500 series
nVidia Quadro 400, 600, 2000, 4000 (Mac & Win), CX, 5000, 6000
AMD/ATI Radeon 2000, 3000, 4000, 5000, 6000, 7000 series
AMD/ATI FirePro 3800, 4800, 5800, 7800, 8800, 9800, 3900, 4900, 5900, 7900
Intel Intel HD Graphics, Intel HD Graphics P3000, Intel HD Graphics P4000
Note: ATI X1000 series and nVidia 7000 series cards are no longer being tested and are not officially supported in CS6 – some basic GL functionality may be available for both these cards.
Curt, I have a supported card (ATI Radeon HD 5670) and everything GPU-oriented is turned on and working. The use of the GPU for actual brush painting operations seems to be no different than it was in Photoshop CS5.
It seems you can always get lag if you make a brush big enough. I'd certainly like to hear from someone for whom that's not the case. Only more powerful CPUs seem to make brush painting operations faster. People with the latest i7s, for example, like Trevor find that painting is more interactive.
-Noel
Noel, I am not the expert you are in these matters, not even sure how to test the lag.
I did open a 6500 x 6200 pixel document in both CS5 and CS6. There I used a 500,1500 and 2500 brush sizem 0 hardness. Just looking at it they seem the same but the hard brush was a little faster.
When you advance the brush the larger the brush the longer it takes to fill the circle, but seems to be same on both programs.
I have an ATI HD 5450 card 8 gigs of RAM and an i7 CPU, about 2 years old.
Exactly. It took dragging a huge brush across a giant document and timing with a stopwatch to detect the difference.
Thus my conclusion is that the Mercury graphics engine either isn't accelerating plain old brush painting, or it has been (without being named as such) since Photoshop CS5.
-Noel
I found a fix for this problem.
Found this on Youtube.
http://www.youtube.com/watch?v=_qVdqQOlyRg
Follow the video.
I didnt , i just went to this link http://www.adobe.com/support/downloads/detail.jsp?ftpID=4056 and downloaded the zip file and used all registry entries. Works like a charm now. No lag whatsoever , in Advanced mode. ![]()
P.S - i know it says CS5 on the video and CS4 on the adobe link but it works with CS4 , CS5 and CS6 as well .
iwouldntknow wrote:
hi, do you have anymore details on the smudge bug, or if it'll be fixed soon- it's a tool i use extensively, and it's behaviour in cs6 is pretty disappointing?
A look at the executables in the Photoshop installation area reveals they were updated in mid-March, so virtually none of the problems reported during the public beta are going to have been fixed.
What do you mean, exactly?
That zip file has 4 different registry files in it, some of which do the exact opposite of others. You didn't apply them all did you? And they apply ONLY to Photoshop CS4. You are wrong if you think otherwise.
Chances are all you've done is disable Photoshop CS4 from using your Graphics Processor entirely - something you likely could have done just as well by going into Preferences - Performance and unchecking [ ] Use OpenGL. Now you'll be working without using any GPU acceleration, which may have worked around a driver bug (that you could have fixed another way) but is also going to prevent you from using some very nice features of Photoshop.
You really need to READ THE INSTRUCTIONS.
-Noel
i infact did use them all , but it seems to be fixed now. Also unchecking OpenGL didnt help but these did . I definitely do not know what the reg entries do but as long as photoshop works well.
I made a mess? Well should i reinstall or remove the reg entries?
Okay so how do i fix this then cause hardware cannot be the problem , my system - i7 2600k , 16GB ram , ATI HD6950 2 GB. So what else can be the problem?
Exactly my point.
The specific registry files you downloaded at the exact link you posted above can affect only Photoshop CS4. If you don't have Photoshop CS4 they're doing nothing for you, and you probably need not do anything to undo what you've done (unless you want to run Photoshop CS4 some day).
If you saw something get better, it was a coincidence.
I realize you were trying to be helpful up above, but posting bogus info isn't helpful. It just serves to mislead people and waste their time.
-Noel
im having same problem..
mouse feels slow compared to cs5 and only when graphic processor is on, all settings same.
and i just noticed when opening the liquify, then the mouse is laggy and slow but when holding down the button to liquify the later its smooth and normalt,
whats wrong there O.o?.
If it's actually faster when the GPU is disabled, then you definitely have some kind of unexpected display driver issue.
Does everyone with this issue have nVidia? Perhaps it would be good to start listing video card model and driver version in posts in this thread.
I can confirm it's NOT happening with ATI Radeon HD 5670 and Catalyst 12.2 driver package.
-Noel
Noel:
Just ran the same test as you using the Standard Brush and I am seeing zero lag with the same size test image you used. I am using an i7 machine, 16GB RAM with the Intel Graphics P4000 card with the latest drivers with GPU enabled. Using the Blur tool I do see a noticeable lag using the Smudge and Blur tools. With the Blur tool far being the worst offender
Not sure if this helps, but another data point
MK
Update: with a 900 px blur setting, it actually caused Pshop to go into a non-responsive state and had to force a close (first for me on CS6) but when I opened CS6, the test image recovered, whooo, so proved that auto recovery works ![]()
Funny thing is although Photoshop hung, it was nowhere maxed out on any resources, normal memory utilization, CPU's averaging 21%
my specs:
Motherboard: Asrock Fatality P67 Performance
Cpu: Intel Core i7 2600k 3.4 Ghz
Graphic Card: Nvidia Geforce GTX 460 OC
Ram: 6.0GB
Hard Drives: 60gb intel 520 SSD - system and photoshop here
977GB Western Digital WDC WD10EAVS-00D7B1 ATA Device (IDE)
Audio: Realtek High Definition Audio
Yes
i have the newest updated drivers (296.10) for my Nvidia Geforce 460 GTX and everything else updateable.
