I am developing an export filter and I'm looking for a way to determine if an LRPhoto has any adjustments applied (i.e. if the "Photo has Develop adjustments" icon is displayed).
Since I couldn't find anything in the API, I am now using LRPhoto:getDevelopSettings() and check if some common settings are different from their default.
Of course, this is quite fragile, so I'd like to know if there is a better way to do that.
Invoke catalog:findPhotos() with the criterion "hasAdjustments = true AND filename starts with <filename>", then test whether the photo is in the array of photos returned. This should be pretty fast to invoke for each photo in question. If not, you can invoke it on the entire catalog and cache the results.
The solution works good, but has a severe performance impact.
I tested it on 1500 photo's and my loop with and without increased from 11 seconds to 90 seconds.
This is an expensive operation.
Something tells me there should be a quicker way, but I have not found it yet.
BTW why do you suggest filename starts with <filename>" and not contains all?
I used the code below where "name" is the name from the photo:
local name = photo:getFormattedMetadata( "fileName" )
local foundPhotos = catalog:findPhotos {
searchDesc = {
criteria = "hasAdjustments",
operation = "isFalse",
value = true,
criteria = "filename",
operation = "all",
value = name,
value2 = "",
combine = "intersect",
Hi Rob,
Still, I find it strange that in there is not a "hasAdjustments" in photo:getDevelopSettings(). That would solve this problem.
I checked it with the debug toolkit from John Ellis.
You are right, I should try the 2e solution. Thanks.
My plugin loops through a group of selected photos (<= 1500). It checks if a photo has adjustments.
A photographer college has 2 catalogs of each 150K. As far as I understand the catalog:findPhotos function works on an entire catalog. That would mean it would retrieve all photos with no adjustments.
Probably that would be more than 100K for him. Would it then still be faster?
You can do some benchmarking - John Ellis debugging toolkit is ideal for that purpose.
But, findPhotos is generally quite fast compared to some other functions like those that get keywords. I assume it's wired fairly directly to the sqlite engine. But, John Ellis is the leading expert in this domain.
If you expect most photos *will* have adjustments you could invert the sense of it.
Let us know what you discover, OK?
Cheers,
Rob
I did a quick performance measurement, and using catalog:findPhotos() to get the "hasAdjustments" status of all photos of the catalog into a table is far faster than doing it one photo at a time. Details:
We've discussed two variants:
A. Extract the status of all photos from the catalog at once and put them in a table for fast access:
hasAdjustments = false
B. Extract the status one photo at a time using the "filename" criterion to limit the search.
hasAdjustments = false AND filename startsWith <filename>
I tested on a LR 3.6 catalog with 19K photos, 17K of which didn't have adjustments. Method A took a total of 0.14 seconds for the entire catalog, while method B took 0.2 seconds/ photo. So clearly, method A is always better to use.
LR 4 has made many catalog operations faster. In LR 4.1 RC2, method B took 0.02 seconds/photo, ten times faster. But method A is still superior if you're handling more than a few photos.
I think it's quite reasonable to expect that method A would still perform comparably on a catalog 10 times as large. The resulting table would take just a few megabytes of memory.
I agree that it would be more convenient if photo:getRawMetadata() supported "hasAdjustments". But method A would still be faster, since catalog:batchGetRawMetadata() can only process a couple thousand photos per second, whereas method A goes two order of magnitudes faster.
Here's the test script:
Profile the performance of using catalog:findPhotos () to extract
whether a photo has adjustments.
local Require = require 'Require'.path ("../common")
local Debug = require 'Debug'.init ()
require 'strict'
local LrApplication = import 'LrApplication'
local LrFunctionContext = import 'LrFunctionContext'
local Util = require 'Util'
local catalog = LrApplication.activeCatalog ()
local showErrors = Debug.showErrors
local function findPhotosOnePhoto (filename)
return catalog:findPhotos {
searchDesc = {combine = "intersect",
{criteria = "hasAdjustments", operation = "isFalse",
value = true},
{criteria = "filename", operation = "startsWith", value = filename,
value2 = ""},
{criteria = "filename", operation = "endsWith", value = filename,
value2 = ""}}}
end
local function getPhotoFilename (photo)
return photo:getFormattedMetadata ("fileName")
end
local function findOne ()
local nFound, nExamined = 0, 0
local photos = catalog:getAllPhotos ()
for i, photo in ipairs (photos) do
if i > 100 then break end
local filename = getPhotoFilename (photo)
local foundPhotos = findPhotosOnePhoto (filename)
for i, foundPhoto in ipairs (foundPhotos) do
nExamined = nExamined + 1
if photo == foundPhoto then nFound = nFound + 1; break end
end
end
return nFound, nExamined
end
local function findAll ()
value = true}}}
local hasAdjustments = {}
for i, photo in ipairs (foundPhotos) do
hasAdjustments [photo] = true
end
return #foundPhotos
end
LrFunctionContext.postAsyncTaskWithContext ("test", showErrors (function (context)
findOne = Debug.profileFunc (findOne, "findOne")
findAll = Debug.profileFunc (findAll, "findAll")
findPhotosOnePhoto = Debug.profileFunc (findPhotosOnePhoto,
"findPhotosOnePhoto")
getPhotoFilename = Debug.profileFunc (getPhotoFilename, "getPhotoFilename")
Debug.logn ("findOne", findOne ())
Debug.logn ("findAll", findAll ())
Debug.logn (Debug.profileResults ())
end))
Results performance test
With the above script I did the performance test on a 15k and 156k database.
1) On a database with 15k photos:
12/05/28 08:13:55com.johnrellis.logger TRACE
Function calls top calls time time/call time/top
findPhotosOnePhoto 100 100 6.33760 0.06338 0.06338
findAll 1 1 0.05500 0.05500 0.05500
findOne 1 1 6.45510 6.45510 6.45510
getPhotoFilename 100 100 0.04750 0.00047 0.00047
On a database with 156k photos:
12/05/28 08:16:29com.johnrellis.logger TRACE
findPhotosOnePhoto 100 100 70.19358 0.70194 0.70194
findAll 1 1 0.71001 0.71001 0.71001
findOne 1 1 71.38110 71.38110 71.38110
getPhotoFilename 100 100 0.40250 0.00403 0.00403
Lightroom sytem info
Lightroom version: 4.0 [814577]
Operating system: Windows 7 Home Premium Edition
Version: 6.1 [7601]
Application architecture: x64
System architecture: x64
Physical processor count: 8
Processor speed: 3,4 GHz
Built-in memory: 8173,1 MB
Real memory available to Lightroom: 8173,1 MB
Very interesting -- confirms that method A is practical on large catalogs.
Also, it looks like there is a performance anomaly with LR's use of the database with method B. In the application, you can do
and the results for the entire catalog appear very quickly, indicating that there is a text index on that field. But the timings of catalog:findPhotos() in method B are not providing the same performance. Not worth pursuing, though.
I submitted a feature request, see http://feedback.photoshop.com/photoshop_family/topics/lr_sdk_add_funct ions_that_check_reports_if_adjustments_have_been_applied_to_photo
