Hello, new to coding, but using tiny 1 minute swf videos for web narrations, 320x240.
Going with swf because the flv is less than 3 megs and the swf is a tiny 60kb video. I even swaped out the audio for studio sound quality ahead of time and it works great even at that small size. Fantastic Adobe! Compressed using mp4(with enhanced audio) to> flv> to swf.. The flv and swf located in the root site folder.
However, even though it's skinned with playback controls that work, for some reason dreamweaver's swf implementation script forces the swf to start playing automatically.
I embeded the swf using the insert media tab that creates a (lengthy) javascript "swf_modified" script file etc. Works great but can't figure out how to change the autoplay option back to manual.
Autoloop and autoplay are unchecked in the propties panel.
Oh, btw, when doing xhtml slicing out of fireworks into dreamweaver, css with in line table slices, can I just delete a 320 x 240 block in dreamweaver and insert the media into the empty box lilke I have been doing? Or are there some browsers that require a div tag and if so does that take up any pixel space that might break apart the slicing in certain browsers?
Hope I explained that clearly enough..
Thanks adobe and thanks everybody!
John
Thanks for your help. Yes tried addding that but same. There is a paramter almost identical but says "play" instead and it's set to false in all instances, but couldn't locate such tags in the javascript code.
The default dreamweaver code is lengthy, hope that's ok? Could it have something to do with setting the "express install" as active maybe?
/*! SWFObject v2.0 <http://code.google.com/p/swfobject/>
Copyright (c) 2007 Geoff Stearns, Michael Williams, and Bobby van der Sluis
This software is released under the MIT License <http://www.opensource.org/licenses/mit-license.php>
var swfobject = function() {
var UNDEF = "undefined",
OBJECT = "object",
SHOCKWAVE_FLASH = "Shockwave Flash",
SHOCKWAVE_FLASH_AX = "ShockwaveFlash.ShockwaveFlash",
FLASH_MIME_TYPE = "application/x-shockwave-flash",
EXPRESS_INSTALL_ID = "SWFObjectExprInst",
win = window,
doc = document,
nav = navigator,
domLoadFnArr = [],
regObjArr = [],
timer = null,
storedAltContent = null,
storedAltContentId = null,
isDomLoaded = false,
isExpressInstallActive = false;
/* Centralized function for browser feature detection
- Proprietary feature detection (conditional compiling) is used to detect Internet Explorer's features
- User agent string detection is only used when no alternative is possible
- Is executed directly for optimal performance
var ua = function() {
var w3cdom = typeof doc.getElementById != UNDEF && typeof doc.getElementsByTagName != UNDEF && typeof doc.createElement != UNDEF && typeof doc.appendChild != UNDEF && typeof doc.replaceChild != UNDEF && typeof doc.removeChild != UNDEF && typeof doc.cloneNode != UNDEF,
playerVersion = [0,0,0],
d = null;
if (typeof nav.plugins != UNDEF && typeof nav.plugins[SHOCKWAVE_FLASH] == OBJECT) {
d = nav.plugins[SHOCKWAVE_FLASH].description;
if (d) {
d = d.replace(/^.*\s+(\S+\s+\S+$)/, "$1");
playerVersion[0] = parseInt(d.replace(/^(.*)\..*$/, "$1"), 10);
playerVersion[1] = parseInt(d.replace(/^.*\.(.*)\s.*$/, "$1"), 10);
playerVersion[2] = /r/.test(d) ? parseInt(d.replace(/^.*r(.*)$/, "$1"), 10) : 0;
else if (typeof win.ActiveXObject != UNDEF) {
var a = null, fp6Crash = false;
try {
a = new ActiveXObject(SHOCKWAVE_FLASH_AX + ".7");
catch(e) {
try {
a = new ActiveXObject(SHOCKWAVE_FLASH_AX + ".6");
playerVersion = [6,0,21];
a.AllowScriptAccess = "always"; // Introduced in fp6.0.47
catch(e) {
if (playerVersion[0] == 6) {
fp6Crash = true;
if (!fp6Crash) {
try {
a = new ActiveXObject(SHOCKWAVE_FLASH_AX);
catch(e) {}
if (!fp6Crash && a) { // a will return null when ActiveX is disabled
try {
d = a.GetVariable("$version"); // Will crash fp6.0.21/23/29
if (d) {
d = d.split(" ")[1].split(",");
playerVersion = [parseInt(d[0], 10), parseInt(d[1], 10), parseInt(d[2], 10)];
catch(e) {}
var u = nav.userAgent.toLowerCase(),
p = nav.platform.toLowerCase(),
webkit = /webkit/.test(u) ? parseFloat(u.replace(/^.*webkit\/(\d+(\.\d+)?).*$/, "$1")) : false, // returns either the webkit version or false if not webkit
ie = false,
windows = p ? /win/.test(p) : /win/.test(u),
mac = p ? /mac/.test(p) : /mac/.test(u);
/*@cc_on
ie = true;
@if (@_win32)
windows = true;
@elif (@_mac)
mac = true;
@end
return { w3cdom:w3cdom, pv:playerVersion, webkit:webkit, ie:ie, win:windows, mac:mac };
/* Cross-browser onDomLoad
- Based on Dean Edwards' solution: http://dean.edwards.name/weblog/2006/06/again/
- Will fire an event as soon as the DOM of a page is loaded (supported by Gecko based browsers - like Firefox -, IE, Opera9+, Safari)
var onDomLoad = function() {
if (!ua.w3cdom) {
return;
addDomLoadEvent(main);
if (ua.ie && ua.win) {
try { // Avoid a possible Operation Aborted error
doc.write("<scr" + "ipt id=__ie_ondomload defer=true src=//:></scr" + "ipt>"); // String is split into pieces to avoid Norton AV to add code that can cause errors
var s = getElementById("__ie_ondomload");
if (s) {
s.onreadystatechange = function() {
if (this.readyState == "complete") {
this.parentNode.removeChild(this);
callDomLoadFunctions();
catch(e) {}
if (ua.webkit && typeof doc.readyState != UNDEF) {
timer = setInterval(function() { if (/loaded|complete/.test(doc.readyState)) { callDomLoadFunctions(); }}, 10);
if (typeof doc.addEventListener != UNDEF) {
doc.addEventListener("DOMContentLoaded", callDomLoadFunctions, null);
addLoadEvent(callDomLoadFunctions);
function callDomLoadFunctions() {
if (isDomLoaded) {
return;
if (ua.ie && ua.win) { // Test if we can really add elements to the DOM; we don't want to fire it too early
var s = createElement("span");
var t = doc.getElementsByTagName("body")[0].appendChild(s);
t.parentNode.removeChild(t);
catch (e) {
return;
isDomLoaded = true;
if (timer) {
clearInterval(timer);
timer = null;
var dl = domLoadFnArr.length;
for (var i = 0; i < dl; i++) {
domLoadFnArr[i]();
function addDomLoadEvent(fn) {
if (isDomLoaded) {
fn();
else {
domLoadFnArr[domLoadFnArr.length] = fn; // Array.push() is only available in IE5.5+
/* Cross-browser onload
- Based on James Edwards' solution: http://brothercake.com/site/resources/scripts/onload/
- Will fire an event as soon as a web page including all of its assets are loaded
function addLoadEvent(fn) {
if (typeof win.addEventListener != UNDEF) {
win.addEventListener("load", fn, false);
else if (typeof doc.addEventListener != UNDEF) {
doc.addEventListener("load", fn, false);
else if (typeof win.attachEvent != UNDEF) {
win.attachEvent("onload", fn);
else if (typeof win.onload == "function") {
var fnOld = win.onload;
win.onload = function() {
fnOld();
fn();
else {
win.onload = fn;
/* Main function
- Will preferably execute onDomLoad, otherwise onload (as a fallback)
function main() { // Static publishing only
var rl = regObjArr.length;
for (var i = 0; i < rl; i++) { // For each registered object element
var id = regObjArr[i].id;
if (ua.pv[0] > 0) {
var obj = getElementById(id);
if (obj) {
regObjArr[i].width = obj.getAttribute("width") ? obj.getAttribute("width") : "0";
regObjArr[i].height = obj.getAttribute("height") ? obj.getAttribute("height") : "0";
if (hasPlayerVersion(regObjArr[i].swfVersion)) { // Flash plug-in version >= Flash content version: Houston, we have a match!
if (ua.webkit && ua.webkit < 312) { // Older webkit engines ignore the object element's nested param elements
fixParams(obj);
setVisibility(id, true);
else if (regObjArr[i].expressInstall && !isExpressInstallActive && hasPlayerVersion("6.0.65") && (ua.win || ua.mac)) { // Show the Adobe Express Install dialog if set by the web page author and if supported (fp6.0.65+ on Win/Mac OS only)
showExpressInstall(regObjArr[i]);
else { // Flash plug-in and Flash content version mismatch: display alternative content instead of Flash content
displayAltContent(obj);
else { // If no fp is installed, we let the object element do its job (show alternative content)
/* Fix nested param elements, which are ignored by older webkit engines
- This includes Safari up to and including version 1.2.2 on Mac OS 10.3
- Fall back to the proprietary embed element
function fixParams(obj) {
var nestedObj = obj.getElementsByTagName(OBJECT)[0];
if (nestedObj) {
var e = createElement("embed"), a = nestedObj.attributes;
if (a) {
var al = a.length;
for (var i = 0; i < al; i++) {
if (a[i].nodeName.toLowerCase() == "data") {
e.setAttribute("src", a[i].nodeValue);
else {
e.setAttribute(a[i].nodeName, a[i].nodeValue);
var c = nestedObj.childNodes;
if (c) {
var cl = c.length;
for (var j = 0; j < cl; j++) {
if (c[j].nodeType == 1 && c[j].nodeName.toLowerCase() == "param") {
e.setAttribute(c[j].getAttribute("name"), c[j].getAttribute("value"));
obj.parentNode.replaceChild(e, obj);
/* Fix hanging audio/video threads and force open sockets and NetConnections to disconnect
- Occurs when unloading a web page in IE using fp8+ and innerHTML/outerHTML
- Dynamic publishing only
function fixObjectLeaks(id) {
if (ua.ie && ua.win && hasPlayerVersion("8.0.0")) {
win.attachEvent("onunload", function () {
if (obj) {
for (var i in obj) {
if (typeof obj[i] == "function") {
obj[i] = function() {};
obj.parentNode.removeChild(obj);
/* Show the Adobe Express Install dialog
- Reference: http://www.adobe.com/cfusion/knowledgebase/index.cfm?id=6a253b75
function showExpressInstall(regObj) {
isExpressInstallActive = true;
var obj = getElementById(regObj.id);
if (obj) {
if (regObj.altContentId) {
var ac = getElementById(regObj.altContentId);
if (ac) {
storedAltContent = ac;
storedAltContentId = regObj.altContentId;
else {
storedAltContent = abstractAltContent(obj);
if (!(/%$/.test(regObj.width)) && parseInt(regObj.width, 10) < 310) {
regObj.width = "310";
if (!(/%$/.test(regObj.height)) && parseInt(regObj.height, 10) < 137) {
regObj.height = "137";
doc.title = doc.title.slice(0, 47) + " - Flash Player Installation";
var pt = ua.ie && ua.win ? "ActiveX" : "PlugIn",
dt = doc.title,
fv = "MMredirectURL=" + win.location + "&MMplayerType=" + pt + "&MMdoctitle=" + dt,
replaceId = regObj.id;
// For IE when a SWF is loading (AND: not available in cache) wait for the onload event to fire to remove the original object element
// In IE you cannot properly cancel a loading SWF file without breaking browser load references, also obj.onreadystatechange doesn't work
if (ua.ie && ua.win && obj.readyState != 4) {
var newObj = createElement("div");
replaceId += "SWFObjectNew";
newObj.setAttribute("id", replaceId);
obj.parentNode.insertBefore(newObj, obj); // Insert placeholder div that will be replaced by the object element that loads expressinstall.swf
obj.style.display = "none";
win.attachEvent("onload", function() { obj.parentNode.removeChild(obj); });
createSWF({ data:regObj.expressInstall, id:EXPRESS_INSTALL_ID, width:regObj.width, height:regObj.height }, { flashvars:fv }, replaceId);
/* Functions to abstract and display alternative content
function displayAltContent(obj) {
var el = createElement("div");
obj.parentNode.insertBefore(el, obj); // Insert placeholder div that will be replaced by the alternative content
el.parentNode.replaceChild(abstractAltContent(obj), el);
else {
obj.parentNode.replaceChild(abstractAltContent(obj), obj);
function abstractAltContent(obj) {
var ac = createElement("div");
if (ua.win && ua.ie) {
ac.innerHTML = obj.innerHTML;
else {
if (nestedObj) {
if (c) {
var cl = c.length;
for (var i = 0; i < cl; i++) {
if (!(c[i].nodeType == 1 && c[i].nodeName.toLowerCase() == "param") && !(c[i].nodeType == 8)) {
ac.appendChild(c[i].cloneNode(true));
return ac;
/* Cross-browser dynamic SWF creation
function createSWF(attObj, parObj, id) {
var r, el = getElementById(id);
if (typeof attObj.id == UNDEF) { // if no 'id' is defined for the object element, it will inherit the 'id' from the alternative content
attObj.id = id;
if (ua.ie && ua.win) { // IE, the object element and W3C DOM methods do not combine: fall back to outerHTML
var att = "";
for (var i in attObj) {
if (attObj[i] != Object.prototype[i]) { // Filter out prototype additions from other potential libraries, like Object.prototype.toJSONString = function() {}
if (i == "data") {
parObj.movie = attObj[i];
else if (i.toLowerCase() == "styleclass") { // 'class' is an ECMA4 reserved keyword
att += ' class="' + attObj[i] + '"';
else if (i != "classid") {
att += ' ' + i + '="' + attObj[i] + '"';
var par = "";
for (var j in parObj) {
if (parObj[j] != Object.prototype[j]) { // Filter out prototype additions from other potential libraries
par += '<param name="' + j + '" value="' + parObj[j] + '" />';
el.outerHTML = '<object classid="clsid:D27CDB6E-AE6D-11cf-96B8-444553540000"' + att + '>' + par + '</object>';
fixObjectLeaks(attObj.id); // This bug affects dynamic publishing only
r = getElementById(attObj.id);
else if (ua.webkit && ua.webkit < 312) { // Older webkit engines ignore the object element's nested param elements: fall back to the proprietary embed element
var e = createElement("embed");
e.setAttribute("type", FLASH_MIME_TYPE);
for (var k in attObj) {
if (attObj[k] != Object.prototype[k]) { // Filter out prototype additions from other potential libraries
if (k == "data") {
e.setAttribute("src", attObj[k]);
else if (k.toLowerCase() == "styleclass") { // 'class' is an ECMA4 reserved keyword
e.setAttribute("class", attObj[k]);
else if (k != "classid") { // Filter out IE specific attribute
e.setAttribute(k, attObj[k]);
for (var l in parObj) {
if (parObj[l] != Object.prototype[l]) { // Filter out prototype additions from other potential libraries
if (l != "movie") { // Filter out IE specific param element
e.setAttribute(l, parObj[l]);
el.parentNode.replaceChild(e, el);
r = e;
else { // Well-behaving browsers
var o = createElement(OBJECT);
o.setAttribute("type", FLASH_MIME_TYPE);
for (var m in attObj) {
if (attObj[m] != Object.prototype[m]) { // Filter out prototype additions from other potential libraries
if (m.toLowerCase() == "styleclass") { // 'class' is an ECMA4 reserved keyword
o.setAttribute("class", attObj[m]);
else if (m != "classid") { // Filter out IE specific attribute
o.setAttribute(m, attObj[m]);
for (var n in parObj) {
if (parObj[n] != Object.prototype[n] && n != "movie") { // Filter out prototype additions from other potential libraries and IE specific param element
createObjParam(o, n, parObj[n]);
el.parentNode.replaceChild(o, el);
r = o;
return r;
function createObjParam(el, pName, pValue) {
var p = createElement("param");
p.setAttribute("name", pName);
p.setAttribute("value", pValue);
el.appendChild(p);
function getElementById(id) {
return doc.getElementById(id);
function createElement(el) {
return doc.createElement(el);
function hasPlayerVersion(rv) {
var pv = ua.pv, v = rv.split(".");
v[0] = parseInt(v[0], 10);
v[1] = parseInt(v[1], 10);
v[2] = parseInt(v[2], 10);
return (pv[0] > v[0] || (pv[0] == v[0] && pv[1] > v[1]) || (pv[0] == v[0] && pv[1] == v[1] && pv[2] >= v[2])) ? true : false;
/* Cross-browser dynamic CSS creation
- Based on Bobby van der Sluis' solution: http://www.bobbyvandersluis.com/articles/dynamicCSS.php
function createCSS(sel, decl) {
if (ua.ie && ua.mac) {
return;
var h = doc.getElementsByTagName("head")[0], s = createElement("style");
s.setAttribute("type", "text/css");
s.setAttribute("media", "screen");
if (!(ua.ie && ua.win) && typeof doc.createTextNode != UNDEF) {
s.appendChild(doc.createTextNode(sel + " {" + decl + "}"));
h.appendChild(s);
if (ua.ie && ua.win && typeof doc.styleSheets != UNDEF && doc.styleSheets.length > 0) {
var ls = doc.styleSheets[doc.styleSheets.length - 1];
if (typeof ls.addRule == OBJECT) {
ls.addRule(sel, decl);
function setVisibility(id, isVisible) {
var v = isVisible ? "inherit" : "hidden";
if (isDomLoaded) {
getElementById(id).style.visibility = v;
else {
createCSS("#" + id, "visibility:" + v);
function getTargetVersion(obj) {
if (!obj)
return 0;
var c = obj.childNodes;
var cl = c.length;
if (c[i].nodeType == 1 && c[i].nodeName.toLowerCase() == "object") {
c = c[i].childNodes;
cl = c.length;
i = 0;
if (c[i].nodeType == 1 && c[i].nodeName.toLowerCase() == "param" && c[i].getAttribute("name") == "swfversion") {
return c[i].getAttribute("value");
return 0;
function getExpressInstall(obj) {
if (!obj)
return "";
var cl = c.length;
cl = c.length;
i = 0;
if (c[i].nodeType == 1 && c[i].nodeName.toLowerCase() == "param" && c[i].getAttribute("name") == "expressinstall") {
return "";
return {
/* Public API
- Reference: http://code.google.com/p/swfobject/wiki/SWFObject_2_0_documentation
registerObject: function(objectIdStr, swfVersionStr, xiSwfUrlStr) {
if (!ua.w3cdom || !objectIdStr) {
return;
var obj = document.getElementById(objectIdStr);
var xi = getExpressInstall(obj);
var regObj = {};
regObj.id = objectIdStr;
regObj.swfVersion = swfVersionStr ? swfVersionStr : getTargetVersion(obj);
regObj.expressInstall = xiSwfUrlStr ? xiSwfUrlStr : ((xi != "") ? xi : false);
regObjArr[regObjArr.length] = regObj;
setVisibility(objectIdStr, false);
getObjectById: function(objectIdStr) {
var r = null;
if (ua.w3cdom && isDomLoaded) {
var o = getElementById(objectIdStr);
if (o) {
var n = o.getElementsByTagName(OBJECT)[0];
if (!n || (n && typeof o.SetVariable != UNDEF)) {
r = o;
else if (typeof n.SetVariable != UNDEF) {
r = n;
return r;
embedSWF: function(swfUrlStr, replaceElemIdStr, widthStr, heightStr, swfVersionStr, xiSwfUrlStr, flashvarsObj, parObj, attObj) {
if (!ua.w3cdom || !swfUrlStr || !replaceElemIdStr || !widthStr || !heightStr || !swfVersionStr) {
return;
widthStr += ""; // Auto-convert to string to make it idiot proof
heightStr += "";
if (hasPlayerVersion(swfVersionStr)) {
setVisibility(replaceElemIdStr, false);
var att = (typeof attObj == OBJECT) ? attObj : {};
att.data = swfUrlStr;
att.width = widthStr;
att.height = heightStr;
var par = (typeof parObj == OBJECT) ? parObj : {};
if (typeof flashvarsObj == OBJECT) {
for (var i in flashvarsObj) {
if (flashvarsObj[i] != Object.prototype[i]) { // Filter out prototype additions from other potential libraries
if (typeof par.flashvars != UNDEF) {
par.flashvars += "&" + i + "=" + flashvarsObj[i];
else {
par.flashvars = i + "=" + flashvarsObj[i];
addDomLoadEvent(function() {
createSWF(att, par, replaceElemIdStr);
if (att.id == replaceElemIdStr) {
setVisibility(replaceElemIdStr, true);
else if (xiSwfUrlStr && !isExpressInstallActive && hasPlayerVersion("6.0.65") && (ua.win || ua.mac)) {
var regObj = {};
regObj.id = regObj.altContentId = replaceElemIdStr;
regObj.width = widthStr;
regObj.height = heightStr;
regObj.expressInstall = xiSwfUrlStr;
showExpressInstall(regObj);
getFlashPlayerVersion: function() {
return { major:ua.pv[0], minor:ua.pv[1], release:ua.pv[2] };
hasFlashPlayerVersion:hasPlayerVersion,
createSWF: function(attObj, parObj, replaceElemIdStr) {
return createSWF(attObj, parObj, replaceElemIdStr);
else {
return undefined;
createCSS: function(sel, decl) {
if (ua.w3cdom) {
createCSS(sel, decl);
addDomLoadEvent:addDomLoadEvent,
addLoadEvent:addLoadEvent,
getQueryParamValue: function(param) {
var q = doc.location.search || doc.location.hash;
if (param == null) {
return q;
if(q) {
var pairs = q.substring(1).split("&");
for (var i = 0; i < pairs.length; i++) {
if (pairs[i].substring(0, pairs[i].indexOf("=")) == param) {
return pairs[i].substring((pairs[i].indexOf("=") + 1));
return "";
// For internal usage only
expressInstallCallback: function() {
if (isExpressInstallActive && storedAltContent) {
var obj = getElementById(EXPRESS_INSTALL_ID);
if (obj) {
obj.parentNode.replaceChild(storedAltContent, obj);
if (storedAltContentId) {
setVisibility(storedAltContentId, true);
storedAltContent.style.display = "block";
storedAltContent = null;
storedAltContentId = null;
