Xeon benchmarks
May 10, 2012 12:02 PM
ok after much fun (sarcasm), delays, too dang busy to get to it. Dual Xeons along with Ivy etc.
Premiere Pro CS5 Version 5.5.2Testing
4 WD 1Tb Sata 64 Meg Cache 600 Drives in 2 Raid 0 arrays
Video material - AVCHD 1080P 24 Frame Each Cut to 30 minutes of material
Export Codec - H264 HDTV 1080P 24 Preset Default
4 Effects per Layer - Fast Color Corrector, Brightness & Contrast, Video Limiter, Sharpen
Each Layer Scaled to 50% for 4 frame PinP view.
Dual Xeon E5-2760 2.6GHz 8 core x2. 16 cores 32 threads
64gig  1600 ram
570 2.5G
3 Layer - 36:53
4 Layer - 38:07
basically on par with a stock 990
SINGLE <--  E5 2670 @ 2.6 GHz
32GB  1600
570GTX 2.5GB
4  1Tb Sata 32 Meg Cache 600 Drives in 2 Raid 0 arrays
3 Layer -
4 Layer - 40:41
I7 3770 4.7 GHz
16GB Top Power 1600
570 2.5G
3 Layer – 29:45
4 Layer – 32:58
X79 3.3 @ 4.5 GHz
32GB  1333
580GTX 3GB
3 Layer - 27:43
4 Layer - 30:02
so anyone want to buy a Xeon..?
will ask Intel for a pair of 3.1GHz but rather pointless
Scott
ADK
    May 10, 2012 2:48 PM   in reply to Scott Chichelli
    I have a new server I've built here with Dual E5-2640's on a Supermicro X9Dai motherboard running Server 2008RC2, its scoring just over 16 on Cinebench R11.5. Its much faster than my i7 3930k w/mild OC which hits around 11.6 on Cinebench. Maybe the dual E5 setup will work better under CS6, but the E5's are easily more powerful than the previous Xeons so not sure why your scores are so bad with those killer CPU's.
    May 10, 2012 3:06 PM   in reply to Scott Chichelli
    Back around 2004, I went to an Adobe "Roadshow".  At that time, the company I worked with was using the Matrox RT.X100 in the Asus P4C800 Deluxe motherboards.  That was a nightmare experience as a side note. Adobe reps mentioned during the presentation that they used Xeons for system stability.  I recently read on Intel's website that memory errors are very rare.  Or did they say extremely rare?  I don't remember. It's my take that ECC memory is best suited for servers.  Not sure if ECC memory + Xeons would make that much of a stability difference for video editors.  So if they're much more expensive, not considerably more stable and insult to injury... slower, why would any editor spend the money on a dual Xeon editing system?  I suppose there could be an advantage with Xeons for usual editing plus 3d work.  What's your take Scott?
    May 10, 2012 3:18 PM   in reply to Scott Chichelli
    Slightly different evidence from Toms Hardware showing ES- 2687 superiority over i7-3960 for specified function.
    Im sure with over clocking the 3960s performance would incresse, but when Im running editing sessions and rendering 20 hours a day (5-7 days a week) Im not that comforable running machines over clocked.
    May 10, 2012 4:44 PM   in reply to Scott Chichelli
    Scott, great information thanks much.  One minor questions should that dual system processor be an E5-2670?
    May 10, 2012 5:55 PM   in reply to Chuck A. McIntyre
    Of course most servers are designed to run using ECC ram because of the Xeon processors, but ECC ram is certainly never used for greater performance, its supposed upside is stability in 24/7 uptime environments but Ive got plenty of mission critical equipment that doesnt run ECC Ram and works just fine.
    The moral of the story is simple
    Do.you want the fastest machine? Get the new Xeon E7's, and run the Maximus setup aka Tesla card.
    A regular i7 with a Gtx580 will beat up a dual Xeon with a videocard unsupported by PP because even all the additional CPU power cant match the effectiveness of the GPU acceleration.
    The new Xeons are awesome, but I went with Supermicro because the their motherboards are solid. For dual 2011 LGA build  I would only have run Supermicro or Asus. If i were going with off the shelf machines, a Z800/820 would be the choice. I run them 24/7 and they never fail.
    May 11, 2012 7:33 AM   in reply to Scott Chichelli
    Scott, actually you assume to much.
    In my extended dialogs with Eric, he understands the scope of the kind of projects I work on (Red, Prores 444, 3D raytracing animation now available in AE CS6, etc.) and concurs with my selection I think you tend to mistakenly assume that all editors here at the site are hobbyists or work strictly on basic projects like weddings or family videos. That is not the case with me and a large influx of folks now gravitating to PrP. And its something you should to understand since the needs of this influx can be different than what you have been used to in the past. Red and Proress 444 (from Alexa) are used a lot in the industry these days and many folks need a system that is diverse enough to cover a wide range of projects, from simple to complex.
    On a different note - FYI th Quadro 4000 is necessary for folks want to leverage more speed when dealing with the new raytracing mode in AE. And since dynamic tracking is rock solid, lots of folks will want to.
    Here are examples of the kind of projects I do and clients I edit with that will greatly benefit from the dual xeon system I purchase.   www.hdshotsandcut.com
    It may be time to be more open minded to the varying needs of new potential customers
    May 11, 2012 7:30 AM   in reply to Scott Chichelli
    Oh BS,
    The Xeons are undenably more powerful, and just because Premiere Pro doesn't exploit their strengths doesn't mean much. By any measurable statistic, the E5/E7 upper end  Xeons are easily more powerful than my overclocked 3930k systems (even with my Dual Xeon machine running ECC and peaking at 2.8ghz)
    I've got people bouncing between AE, PP, Cinema 4D, and I would never give them a mega-clocked i7 for mission critical broadcast installations.
    A Xeon isn't inherently more stable thats true, but workstation class motherboards are a ton better than the average desktop garbage so the whole sum of the components is relevent to the stability, not whether its a i7 or Xeon.
    May 11, 2012 7:59 AM   in reply to Scott Chichelli
    You missed my point Scott...you assumed to much about ME and my needs. Without knowing the kind of projects I worked on (or listening to my needs for my work flow), you did me the disservice of making repeated recommendations that were ill informed...
    (Tom we have been telling you from day one you dont need a Xeon.)
    Listen more... talk less....
    May 11, 2012 8:14 AM   in reply to Scott Chichelli
    PLENTY of mission critical servers are built with Supermicro hardware, I could care less that you think they are horrible.
    An OC'd system is an OC'd system. Thats purely your opinion that its no less stable that running a CPU outside its design parameters, which is pure ignorance.
    And you would discredit any kind of mathematical benchmark , but are content to ONLY include PP as a litmus test for the performance value of a Xeon?
    Whatever....
    So now the Xeon's shine with 4k? Who would have guessed given such a horsepower advantage over an i7.....
    May 14, 2012 3:04 PM   in reply to FloridaG
    The Dual Xeons in testing give far greater performance headroom ie Red material. It's not that Premiere does not utilize all the cores. It's simply as stated before, once you have enough threads to handle encoding/decoding then GHz is the deciding factor with the MPE acceleration. So with the hardware acceleration GHz is the performance factor once you exceed 8 to 12 threads with most codecs. However AE is different. Dual Xeons perform far better in AE then single cpu systems because threading and ram ceiling are the primary factors. The difference in AE renders between Single and Dual CPU system is significant 2 to 1 or greater provided you have the ram to support that many threads. So with AE or other compositors then the Dual Xeon systems would be the ideal choice. Just make sure you have the ram to support 32 threads.
    On a side note, a client of ours found the file to add cards to the acceleration in AE with ray tracing. So you do not need a Quadro card/Open GL for acceleration for that.
    Eric
    ADK
