Exporting a Layered PSD and Overprint Fill
May 9, 2012 11:33 AM
Tags: #illustrator #adobe #export #fill #psd #attributes #overprint
Hi guys.
I'm trying to export a layered PSD of my AI file and I keep having problems with it merging the layers because of the overprint settings.
I've been trying to go through and turn off the overprint in my objects, but I have a photo that's cropped by a rectangle shape, and the Overprint Fill option under Attributes is greyed out. What must I do?
  • Mathias17
    Feb 20, 2012
    May 9, 2012 11:57 AM   in reply to Benjamin Jancewicz
    The photo must have a rectangular Clipping Mask, and you're actually selecting the Clipping Mask Group that was created as a result of the photo being "cropped" to the Clipping Mask. You want the photo within.
    OPTIONS:
    1. Enter the Clipping Mask Group in order to select the photo within (double-click to enter  -OR-  click photo with Direct Selection Tool  -OR-  select Clipping Mask Group and click the Edit Contents button located in the top-docked Control Panel)
    2. Release the Clipping Mask (CTRL+ALT+7  -OR-  Object > Clipping Mask > Release)
    May 10, 2012 10:10 PM   in reply to Benjamin Jancewicz
    You have a linked image.
    Embed the image and overprint will be available but take notice that you cannot overprint a process image over a process color, so you have either have spot color under it or you want to actually use the Multiply mode in the Transparency panel.
    May 10, 2012 10:16 PM   in reply to Wade_Zimmerman
    Before someone jumps in and says but you can print a process image over a solid process color. that is true but only to some degree and the results are difficult to perdict.
    At any rate you need to embed the image.
    May 14, 2012 8:40 AM   in reply to Benjamin Jancewicz
    Why do you think that the overprint settings are the problem? Did you use any overprint settings?
    May 14, 2012 9:04 AM   in reply to Benjamin Jancewicz
    That is normal the way it is displayed if you want evverything you selected to be overprint then click on the box again.
    All the dash mark means is that some items are set for overprint and some are not.
    But also that looks like those layouts are web pages why would you set the art to overprint?
    May 16, 2012 8:50 PM   in reply to Benjamin Jancewicz
    There might be an effect that requires the white to be set to overpront.
