change stroke width of frames
May 9, 2012 10:06 PM
Hi Friends,
How to change stroke width of all frames eg:rectangle frame, ellipse frame, polygon frame.
Balaji
    May 9, 2012 11:37 PM   in reply to banl_05
    var doc = app.activeDocument;
    for (var i = 0; i < doc.allPageItems.length; i++) {
        doc.allPageItems[i].strokeWeight = 1;
    May 10, 2012 2:01 AM   in reply to Kasyan Servetsky
    Not a good solution, Kasyan. If the stroke weight is already '1', it won't change!
    Use this instead:
        doc.allPageItems[i].strokeWeight += 1;
    This will change the stroke weight of all frames, as was asked.
    May 10, 2012 5:36 AM   in reply to [Jongware]
    Good point, Jongware. I always have something to learn from you. Thanks.
    May 10, 2012 7:45 AM   in reply to banl_05
    var color = doc.swatches.item("Anotada");
        if (doc.allPageItems[i].strokeColor == color) {
            doc.allPageItems[i].overprintStroke = true;
    May 11, 2012 2:38 AM   in reply to banl_05
    Let's enclose it with try-catch block:
        try {
        catch(err) {
            $.writeln(err.message + ", line: " + err.line);
    Oct 25, 2012 10:25 PM   in reply to banl_05
    Hi everyone,
    Could someone show me how change the stroke of selected page items?
    Here's the code so far:
    var change = app.selection;
    for(var change=0;change<fx.length;change++){
         change[idt].strokeColor = "None";
         change[idt].strokeWeight = 0;
    Many thanks and best.
    gr
    Oct 25, 2012 10:28 PM   in reply to greenrookie
    sorry! should be:
    for(var idt=0;idt<change.length;idt++){
         change[idt].PageItem.strokeColor = "None";
         change[idt].PageItem.strokeWeight = 0;
    Oct 26, 2012 1:26 AM   in reply to greenrookie
    Um, why are you asking a question and then supply a script that answers it?
    Oct 26, 2012 1:35 AM   in reply to [Jongware]
    Hi, sorry, I should have mentioned before that it doesn't work!
    Oct 26, 2012 3:52 AM   in reply to greenrookie
    Okay, it does not work. So what doesn't work?
    (After trying) oh, it says this
    Error Number: 55
    Error String: Object does not support the property or method 'PageItem'
    Your selection already is a page item (or it should be, when you selected just "objects"). Use this instead:
    There is a slight over-kill here, because setting the stroke color to [None] will automatically set the weight to 0, but that's nothing dramatic.
    Oct 26, 2012 4:22 AM   in reply to [Jongware]
    Thanks for the reply Jongware. I tried this earlier in my futile attempts, but the stroke stayed the same on the test 'text frame'
    Maybe I'm saying it wrong - in terms of I would like to select text frames, graphic frames and unassigned ones and set them to "None"
    Do I need to target these pageItems separately?
    (I'm running CS5.5, OSX 10.6)
    Thanks again
    Nov 4, 2012 2:04 AM   in reply to greenrookie
    Found out that removing the line;
    will make it work properly.
    Many thanks again JongWare!
