Error when mouseX is used
May 11, 2012 4:30 AM
Tags: #flash #cs5.5 #actionscript_3.0
I assined x and y positions for a movieclip to mouseX and mouseY. But while executing I am getting the error #1010 A term is undefined and has no properties...
By debugging I found that error is in that line only.
    May 11, 2012 4:38 AM   in reply to bhargavi reddy
    What is the line and what is the error message?
    May 11, 2012 4:45 AM   in reply to bhargavi reddy
    Try using the trace() function to see if tempcell is around when you try to assign it an x value.  While you are at it try tracing everything in that line to see what falls out.
    trace(tempcell, tempcell.x, mouseX);
    tempcell.x = mouseX;
    May 11, 2012 5:21 AM   in reply to bhargavi reddy
    YOu should try to make a habit of using the trace() function, not only for troubleshooting, but equally so as a development tool that you use to check how things are processing as you advance thru a design.
