Finally offical ICS on Galaxy Note
May 10, 2012 10:08 AM
Now that Galaxy Note finally got an offical update to Ice Cream Sandwich, when will I be able to use Photoshop Touch? I checked today to see if i could purchase but it's still showing as not compatible
    May 10, 2012 10:42 AM   in reply to Zen0s
    PS Touch is supported on Android 3.0 (Honeycomb) and higher, but it was meant for 10+ inch tablets. I know the Note is as powerful as a tablet, but technically it's not, especially its screen size (a little over 5 inches).
    Maybe someday in the future Adobe will expand support to smartphones (both Android and iOS).
    May 11, 2012 9:13 AM   in reply to Zen0s
    PS Touch successfully on a smartphone? Sounds like a hack as, to my knowledge, Adobe has not added support.
    (Don't install APKs from unofficial sources, kids. Just a PSA.)
    ON EDIT: Also need to clarify: an 8.9 inch screen is required, not 10+ as I mentioned before.
    May 20, 2012 6:51 AM   in reply to Warunicorn
    I don't see why the screen's physical size is a factor. The resolution of the note is 1280 x 800 which is what most of the first gen honeycomb tablets are using. ICS should have all of the necessary OS componenets and the note is more than capable of handling it with it's resolution. As the OP mentioned there are people already successfully running it on rooted devices where the application has been purchased from the play store rather than sideloaded. It seems pointless to me that the device would be prevented from running when all it likely is is a change in compatability requirements form the play store which would take virtually no work from adobe.
    Just to clarify, while the screen is "only" 5.3 inches the resolution meets whatever minimum requirements there are, it also has a stylus which would allow for the use of any buttons that may appear smaller due to the physical size of the device.
    http://www.youtube.com/watch?v=nTTl8ILKsgE
