Incompatible disc warning when burning BD in Premiere Elements 9
May 11, 2012 4:56 AM
I am trying to burn a blu-ray disc, but get warning in Premiere Elements 9 that says "incompatible disc".  I am using a BD-R 4x single layer disc.  Why the problem?  What discs are compatible?
    May 11, 2012 6:03 AM   in reply to MrRevo
    That would depend on your disc drive. Have you ensured it is a BluRay burner and that you have the latest drivers?
    Are you using the 64-bit version of Windows 7 as your OS? If so, Premiere Elements 9 may be having trouble interfacing with the 64-bit drivers.
    May 11, 2012 1:03 PM   in reply to MrRevo
    One of the continuing problems with Memorex blank media, is that seem to want to buy the cheapest discs that day, and then rebrand them with the Memorex logo. With DVD's, some users have found discs from up to 4 mfgrs. in the same spindle.
    I would advise against using Memorex blank media in all cases. The same holds for "store brands" too.
    Also, I would check with the burner mfgr. to see if there is a firmware update, as older firmware can create issues too.
    Good luck,
    Hunt
    May 11, 2012 1:08 PM   in reply to Bill Hunt
    I agree with Bill. Although some people never have a problem with them, my first recommendation is to use any brand of media except Memorex.
    But that may or may not be the whole issue here.
    Since your computer is a Dell, go to the Dell site and look up your system's model number. You might be surprised how many updates have been issued, even if your computer is "brand new".
    You can try the free trial of Premiere Elements 10 and see if that makes a difference also. (It comes in a 64-bit Windows 7 version.) But, if all else fails, it may be worth doing what many of us do: Use Premiere Elements to edit our videos and use another program for creating our menus and authoring DVDs and BluRay discs.
    May 11, 2012 1:56 PM   in reply to MrRevo
    60i is essentially the same thing as 30 fps, so you're good there.
    Meantime, why not check out my free 8 part Basic Training tutorials?
    http://forums.adobe.com/thread/537685?tstart=0
    And, if you like it, I've also got a book available that goes into even more step by step detail.
    May 11, 2012 2:07 PM   in reply to MrRevo
    I do not use this, so do not know if it will author BluRay... but it is FREE, so go read
    http://www.deskshare.com/dvd-authoring-burning-software.aspx
    May 11, 2012 2:10 PM   in reply to MrRevo
    The various Save options are to Save the PREL (Project) file. That will only Open in PrE (and with some caveats, PrPro).
    To author, and/or burn the Project, you will want to Share your Timeline. The file format and CODEC, that you choose will depend on the program that you are going to use to author and/or burn. For more background on Project Files & Saving, see this ARTICLE.
    Good luck,
    Hunt
    May 11, 2012 3:28 PM   in reply to MrRevo
    Great news!
    Thank you for reporting your success.
    Happy editing and good luck,
    Hunt
    Nov 20, 2012 12:54 PM   in reply to Bill Hunt
    I am having the same problem.  Incompatibility with disc burn..
    Using win XP pro, APE10,  Disk  HL-DT-ST BD-RE  BH14ns40 BR by LG.
    Testing a video file 25 Seconds long  from MTS clips ,  shot on Canon video Camcorder..
    I have Memorex  andVerbatim BR disks, I bought a second LG burmer. to try but same results..
    I have read as much as I could find. An Stuck.  Hoppy100.
    Nov 20, 2012 1:51 PM   in reply to Hoppy100
    Did you check with LG, to see if there is a firmware update for your BD burner?
    Good luck,
    Hunt
    Nov 20, 2012 2:50 PM   in reply to Bill Hunt
    Hi Bill
    The LG indicated there was no updates for this unit. I also tried to burn this file to a 8.5 folder.
    It said the file was 5+  gig but when I tried to burn it a notifiaction was it weas too large and i could not even burn/Write it to the 8.5 gig folder..  Thanks for your help.
    Nov 27, 2012 5:47 PM   in reply to MrRevo
    I would like to thank ATR,  Bill  Hunt and others  for their help with my
    Share problems.  with their helpa nd sone trial and error on my part I
    laid that problem to rest.
    My new problem is wuth using the Smart Trim Mode and options.
    When I am in APE 10,  Scenline and se;ect several clips to have
    anaylized, I  iright click to  turn on the auto analyzer. Then I  get
    the blue bar and the statement " starting to auto-anaylzer".  Nothing
    happens and I have waited  svveral Hours.
    What am I not doing correctly??
    Thanks Hoppy100.
