RichTaft
How do I get Vertus Fluid Mask 3 to show up under filters in Photoshop CS6
May 11, 2012 2:37 PM
Tags: #cs6 #vertus #fluid_mask
The Fluid mask installer doesn't recognize Photoshop 6.  I selected other and tried to put the “Vertus Fluid Mask 3” folder that contains the files dbghelper.dll & FluidMask3.8bf into the Photoshop 6’s plugins directory.  It’s not available within Photoshop.
It does however function as a freestanding program so I know it works on the computer.  It also worked very well under CS5.
I’m sure Vertus will get around to upgrading, but I’d like to be able to use it with my current projects and not have to wait for them
UPDATE:  The above procedure works for the 32 Bit install of CS6...  Not with the 64Bit....  would like it to work with 64bit since I edit some sizable files
    May 11, 2012 3:14 PM   in reply to RichTaft
    The plugin probably isn't written for 64 bit, you'll need to contact the plugin vendor for updates.
    Jan 23, 2013 4:50 PM   in reply to Chris Cox
    There's a new version out which works as a plug in for CS6 64bit, free update for all FM3 users.
