I am experiencing failures trying to import EDL's created by Premiere Pro CS6 into Speedgrade.
So far I have found 2 scenearios where EDL import will fail with (unsupported edit info: 'W00l' in edit 6) when I try to import the EDL
1. playback speed on clip is less than 100%, it will fail to import.
2. if 'constant gain' audio effect is applied it will fail to import.
wondering are these by design?
Steve
Maybe it's even a nice way to get used to a more steamlined workflow, i don't know. Sending to SpeedGrade also takes forever and crashes regularily, really annoying! Kind of puts the term "SpeedGrade" into a new context, if you have to wait half an hour to start grading. ![]()
cheers,
-- Tim
I just got an error like this.
I do have some transitions and clips in the footage, and because of hte mix of video with timelapse, some go beyond 100% some go below. How do you fix this?
Edit:
I opened the .edl file and this is what is on line 35, I redid the export of the edl file, error changed.
| 035 AX | V | W000 006 00:00:00:00 00:00:02:07 00:02:50:14 00:02:53:11 |
EFFECTS NAME IS W000
* FROM CLIP NAME: MVI_8747.MOV
* TO CLIP NAME: IMG_8692.JPG
| M2 AX | 179.8 | 00:01:34:16 |
| M2 AX | 019.2 | 00:00:00:00 |
its seems its from a movie to a timelapse.
Edit 2: I tried taking away the transition, but its still the same, The constant I see is W000. Whatever that is, its breaking it.
