wayneg2012
How create a single path to type on, not compound path from many paths?
May 11, 2012 9:34 PM
Tags: #paths #compound #shape
I am a bit new to illustrator, but I am having trouble figuring this one out.
I have some negative space I created(black area, see image) that I want to fill with type, not just a simple fill.
Basically I want to create the negative space from a bunch of small minus signs(-) that need to line up as they go across. If I type on each path one at a time as the text doesn't line up that way. This needs to be one continuous path.
Unfortunately if I add them together, it creates a compound path, which you cannot type on, unless I am mistaken? So I need them to be a path, not a compound object.
Hopefully that made sense, any help would be greatly appreciated.
Thank you!
    May 11, 2012 10:24 PM   in reply to wayneg2012
    You should read about the appearance panel which will give you  lot of freedom and expand ypur abilities to do things seem like impossible.
    Here is a video o how to do this, keep in mind if you wish to add text or remove text the the black background will expand or contract accordingly, all you have to do is type as long as the type size and font are the same.
    You can do it with different fonts as well but you will have to adjust the font size baseline shift etc o make them match but it can be done.
    here's the video
    http://www.wadezimmerman.com/videos/NegativeType.mov
    May 11, 2012 10:55 PM   in reply to Wade_Zimmerman
    So with a little adjustments you get this you get this…I use a square character from wingdings and made it a smaller size then the other characters then a baseline shift sufficient to line up with the triangle shape opening in the A and then kerne it serverly so it overlapped that triangle shape but you can just place a white filled path over it and group it with the text.
  • Mathias17
    Feb 20, 2012
    May 11, 2012 11:45 PM   in reply to wayneg2012
    What what what . . .
    Either I'm not following this very well (it is 1:15a here so cut me some slack heh) or all you need to do fill your paths with a pattern, right? In this case, just fill the implied rectangle "behind" the word "-NEGATIVE.", filled with white, with a hyphen lookin' pattern.
    Why bother with Area Type?
    -IF-   you're wanting to fill the black areas in your design with little hyphens that never get cropped/covered up and that look like they follow the shapes they're seemingly filling, that's another matter. Unfortunatley, I have to suggest a blockier font than Futura so that the negative spaces within have a more naturally square area to populate. I think it'll work better, Plus, I think just kocking out the word "NEGATEIVE" from a rectangle sufficiently conveys the concept of negative space. . . . but this isn't the design crit subforum.
    May 12, 2012 3:31 AM   in reply to wayneg2012
    Is this what you were looking for? Essentially, every hyphen in the background that is not fully exposed by the white letterforms (or nearly so) is removed ...
    Ron
    May 13, 2012 3:36 AM   in reply to wayneg2012
    Wayne—
    It looks like you've solved this method, so I didn't spend any more time on the whole text wrap idea, but I thought you might like to see another approach to the whole negative / positive space thing ... first, in black & white: (click image to enlarge)
    And in color:
    Best regards,
    Ron
