I was installing Acrobat x and it was stuck at about 30-ish% in the install, so I cancelled the installation. It now shows 'Installed' without the ability to re-install or do anything. Help!
Hi Jiimy,
I think some to the entries for acrobat was already made till the time you canceled you install.
Could you please try uninstalling Acrobat from Add and remove programs on windows or through Application/Utilities/ Uninstall Acrobat shortcut on Mac and try installing it again.
You can also use Adobe cleaner tool to remove Acrobt entries for this plese go to follwing web page :
I think the suggestion given by Vikas will help you fix the issue.
In case you still face the same issue with acrobat, try running MAC in Safe Boot and chek if it works there. If it does, then it means there is some service or process that is causing the issue and you need to use the hit and trial method to find that out.
Start in Safe Boot mode | Mac OS X : http://helpx.adobe.com/x-productkb/global/start-safe-boot-mode-mac.htm l
I was able to find the cleaner tool about 15 miniutes following my first reply and it helped me to reinstall the app.
However, when I start the application it will remain open for about 10 seconds and then quit. (Mac OSX 10.7.4)
Opening a document exhibits the same behavior.
Here is the kicker! If I quickly open the preferences window for Acrobat X, the program continues running until I close it.
There are no entries in Crash Reporter or any logs that tell what has happened.
I did have CS 5.5 Web Premium installed prior to the upgrade. The uninstall of this suite must have removed a dependant that CS 6 did not replace.
Uninstall Acrobat X from the application uninstaller and then run Cleaner tool for Acrobat X Pro under CS6 and remove files from CS5.5, CS5.
Remove the Acrobat X files and folders from /library/preferences and /users/library/preferences
Restart the computer and install Acrobat from Application Manager.
