TLF + SWC = huge mess
May 6, 2012 11:20 AM
Tags: #flash #as3 #tlf #swc
The scenario is simple, have an SWC that contains some TLF.
include the SWC in an fla and try to create an object of a class in the SWC, it will blow up.
TypeError: Error #1034: Type Coercion failed: cannot convert flash.display::MovieClip@22486f21 to fl.text.TCMText.
    at flash.display::Sprite/constructChildren()
    at flash.display::Sprite()
    at flash.display::MovieClip()
Currently there are no real solutions I can find that will help.
    May 7, 2012 5:57 AM   in reply to Joseph_Saade
    Hi Joseph_saade, you may want to duplicate the question to http://forums.adobe.com/community/flash/flash_general, because it seems a flash pro issue. fl.text.TCMText is a class inside flash pro library.
    May 12, 2012 1:35 AM   in reply to Joseph_Saade
    Hey man, all you got to do is add a TLF text field onto the stage of your FLA, create your SWC from it and Bob's your uncle. I was struggling with this myself for a few hours.
    May 14, 2012 9:23 AM   in reply to Joseph_Saade
    OK. This works if you are not including the swc in an fla but are instead including it in a pure actionscript project (flash builder)
    In fla for swc, let's call it tlfAssetSwc:
    In library path add swc: $(AppConfig)/ActionScript 3.0/libs/11.0/textLayout.swc and set it's linkage to mergeed into code.
    Place any tiny random tlf textfield on the stage.
    Create tlfAssetSwc.swc file
    In actionscript project that uses tlfAssetSwc:
    In library path add swc: tlfAssetSwc, merged into code
    Don't forget to add $(AppConfig)/ActionScript 3.0/libs/tlfruntime.swc merged into code as well.
    I tried it with adding the swc to an fla and you are right it craps out.
    I would suggest using swcs for all your flash-authored assets and then bringing them into a pure action script project. Everything seems to flow so much better...
    Good luck.
