Locked
FMIS doesn't work after upgrade
May 12, 2012 May 12, 2012
Hello all,
1. I'm broadcasting live shows using FMS.
I've upgraded my streaming server to FMIS 3.5 cause I wanted to use the dvrcast app, allowing me to save the stream directly to the server.
The stream is found on the server but I cant watch the stream using the most simple flvplayback setup.
If I broadcast with my FMLE while the component is open on my Flash cs5 stage, I can see the broadcast but the minute I publish it in HTML, all I get is a blank screen.
2. I'm using 4 Sony EX-3 cameras connected to Panasonic av-hs400 live mixer. all connected using HD-SDI.
I'm broadcasting using a laptop with FMLE. What is the best way to connect the live mixer with my laptop?
Thank you,
Liad.
486
Adobe Employee ,
Since you are saying its working on stage - it does not look like FMS problem. But still do you see any errors on server or application logs when you try to playback using HTML.
For second question - i am not sure about that - may be you can post on FMLE forum and see if someone there can help you.
