I'm trying to see if Prelude makes sense for my workflow into Premiere Pro CS6. So far it seems too good to be true, especially the ability to partially injest files into Prelude using IN/OUT points. If I understand correctly, to use this feature I must transcode during injestion even though my native format (HDV/1080p .M2T) works fine in PPro.
So my question, among the many format options that AME offers for Prelude injestion transcoding, is there one I should consider for best Premiere Pro editing performance?
I prefer lossless transcoding for Intermediate files. The only lossless option included with PP is Uncompressed. That can make the files quite large and unwieldy, so I use the free UT codec. It's compressed, so it's smaller (especially in YUV420 mode, which is appropriate for your media). But it's a lossless compression, so there is no degradation at all.
And it works fine with Adobe programs.
Best transcode settings IMO:
MAC:
For stuff shot on consumer cameras, and things that need to be turned around really fast: prores 422 (LT)
For nicer consumer cams / dslrs: ProRes 422
For nice 422 cameras: ProRes 422 (HQ)
For Red / Arri / uncompressed high end cams: ProRes4444
PC or MAC: (less experience, so not sure about details like I am prores)
Avid Codecs: DNxHD and variants.
I've heard good things about Cineform (might just be PC, not sure)
Hope that helps!
Casey
MAC:
Hope that helps!
Casey
The value of this advice is limited as we watch ProRes slowly die as a format to correspond with the decline of Final Cut. Note that at NAB, outboard recorders are shifting focus away from ProRes. So far, it's looking like the lossless codecs proposed here are the UT codec, and DNxHD, though you don't seem to have any experience with them.
I agree that ProRes is a declining format. However, it is still a very valid solution for transcoding. The Adobe suite supports ProRes, (although that's probably to help people switch from FCP.) It may be going down hill, but it is widely accepted and trusted as both an editing format and a delivery format.
And what about RED files? Prelude, SpeedGrade and Premiere are all great tools. They work with RED files natively. However when it comes to doing more with them than just opening and playing them back things get a bit complicated. As far as Prelude is concerned - RED files do not support metadata, so in order to use Prelude i have to transcode. I could do that, but I don't want to sacrifice the realtime editing (due to some 3rd party lossless codec or rendering to a DPX sequence) nor the native color specs of the file.
Jim,
Thanks for the recommendation for the UT Codec. I donwloaded and installed it on my Windows7 system. I rebooted after the install. I guess I'm doing something wrong, because I don't see this codec as an option in AME when I try to create a new preset. Any ideas what I'm doing wrong.
I tried to search AME help for installing 3rd party codecs. Is it just me or is Adobe Help becoming harder and harder to use? I think I need a help file for learning how to use Help.
Thank you.
Taverino wrote:
Jim,
Thank you.
Jim wasn't specific enough. Rather than intuitively choosing "AVI (uncompressed)," choose just AVI as the codec category, and then in the customization settings, you'll find a pop-up menu in the Video Codec section that includes four UT codecs. When you installed UT, it explained via a Read Me file what the relative characteristics of each codec are.
Yup, tried that and I still am not seeing that is posted.
"choose just AVI as the codec category, and then in the customization settings, you'll find a pop-up menu in the Video Codec section that includes four UT codecs"
I have AVI selected - there are no choices for UT in the list and there is no "customization settings"?
See below.
Ok,
Wes' reply did provide the missing info and worked in adding the options to Prelude.
I was able to run a test transcoded file and it did work, HOWEVER - my test GoPro file was 34mb and when this transcoding finished I have a 754mb file! Ridiculous...
Now - not 2 minutes before Wes replied - I got a replay form OLAXVX on another thread (http://forums.adobe.com/message/4601720) who seems to have relatively the same feelings about this whole mess as I do, but has come up with what seems to be a MUCH better solution.
I have tested it a couple of time and at first glans - all seems to work awesome with no transcoding.
