Hello;
I am working on a MacBookPro with OS 10.6.8 and InDesign CS5.
I have reworked the layout of a print version of a book to be an eBook, and have tried exporting it with File > Export for > EPUB and also using the new Kindle plugin (version 7.0), ending up with both .epub and .mobi files. Everything works fine except that none of the endnotes are clickable. I understood that endnotes in eBooks are supposed to be clickable which would be great.
What do I need to do in either the ID setup or export in order to get clickable endnotes in epub/mobi?
Marc
Your title says footnotes but your body text talks about endnotes.
If it is Footnotes: what Steve says (I can back him up on that, although of course "foot"notes will appear as *end*notes in an ePub).
If it is Endnotes: InDesign (1.0, 1.5, 2.0, CS, CS2, CS3, CS4, CS5, Cs5.5, and now CS6...) does not Do endnotes natively, so if you somehow created these it depends on how you did that.
Hello Steve and Jongware;
Thanks for the feedback. Some clarification on my part:
I wrote this book in MS Word with footnotes that I switched to Endnotes in the last phase before importing the file into InDesign to do the final layout of a print version of the book. Both Footnotes and Endnotes in Word act the same way, i.e. you can click the note number to go to the Note and then click the number again to go back to the text.
Does this function not transfer to InDesign when importing?
Hello;
I followed the instructions at the following link and was able to cross-reference all endnote numbers in my text with the endnotes themselves so that when I exported to Kindle (.mobi) I got clickable links. Only problem is, I can click from the text to the endnotes but cannot click back from the endnotes to the source text. This doesn't work in InDesign or in the Kindle file. Isn't a cross reference supposed to work in both directions?
Marc
http://blogs.adobe.com/indesigndocs/2009/03/endnotes_in_indesign_cs4.h tml
