I am trying to lay some animated titles on a music video I have created, Here are my steps:
- Create Project in PP and export as MPEG
- Open After Effects and Create new composition that is same length as clip
- Import Clip to Timeline
- Add and Animate Text
- Export as Premiere Pro Project
When I go to PP and open what I've created I get a message saying "The preset used by one or more sequences in this project requires third party components that could not be located. These sequences will be modified to use a custom sequence setting instead. To continue editing using original preset, quit the aplicationwithout saving the project, re-install and third party components that are required and re-open the project",
The ONLY thing I used is Audition on the Audio, After Effects and Premiere Pro on Video. Please help
I'm not sure if we are having the same problem, but in Adobe Premiere CS6 I have imported a .AEP Comp (Adobe Dynamic Link > Import After Effects Composition) and I cannot, no matter what, drag and drop this comp into a Sequence within Premiere, or even drag it to the New Sequence button in the Project window. This is true of all the attempts, with different .AEP files, I have tried thus far.
Devyn if you hear from them let them know I had the complete opposite problem of you. Your way (Dynamic Link) worked and solved my problem If I go file - import and select the .aep file I get the error. If I go Adobe Dynamic Link > Import After Effects Composition it works fine, I had just come back to post that thats how I fixed my problem thanks guys
It's obvious that the Dynamic Link server is broken in CS6. In almost every project I do, I use dynamic links between AE and PP. I use PP to slice and dice and AE for the effects I pop into my projects. PP is also (or used to be) great for enhancing the sound in animations and video. In CS5 and 5.5, The Dynamic Link server allows me to make changes in AE and they (used to) appear in the other without needing a render to work properly. I have an appropirate card for the Mercury Playback Engine, but the dynamic links no longer play back properly. And the bar above the timeline in PP is red. It used to show as a dynamic link without needing a render (yellow). I cannot work like this, so am going back to CS5.5 until Adobe releases a patch or I'll return my licenses for a refund.
This is a fundamental issue for a feature that obviously hasn't been tested thoroughly. Very poor product testing.
Hmm... It's not all bad. The dynamic link works in the other direction for me (PP to AE); Premiere sequences work fine in After Effects comps—when I make changes in Premiere, they are immediately reflected in the comp in AE. I can not go the other direction yet: using Dynamic Link to get Comps into Premiere, as I previously described above. What happens is the mouse symbol changes to a "Cannot Drop Here" symbol when dragging an AE Comp to any Sequence, or to the new Sequence button within Premiere.
I never had trouble with this in CS5.5. Something may very well be broken, we'll see if others have similar problems.
@RampantSlime I'm glad the Adobe Dynamic Link > Import After Effects Comp worked for you!
You're right, my AE comps have Premiere Pro sequences in them. A test AE Comp with just some Text in it, upon importing into Premiere CS6 goes nicely into Premiere sequences with no hassle.
But an AE Comp with a Premiere Pro sequence embeded into it will not go back to Premiere. Upon testing your accurate assumption, it reveals that I can't go back to Premiere with the Comp I wanted, even if the Premiere sequence embeded into the Comp that I am trying to import is from another .PPROJ file (I was attempting to do this to save render time for the credits sequence of a project, where I cut some footage to go behind the text > sent to After Effects > Created a New PPROJ and imported all the chapters, and then imported the AE Comp, which did not go back in).
That one I know. The Dynamic Link Server only allows one way traffic. It would be interesting if the programming team could not only make it two way, but also multithreaded it to include Photoshop and Illustrator to be included at the same time. Working on a PP timeline while able to link files from AE as well would really make another positive impact on my workflow.
Ah well.
Steve
Sent from somewhere in the ether from my iPhone
Thanks for the help! I assumed otherwise about DL, but now I have RTFM thoroughly: http://help.adobe.com/en_US/premierepro/cs/using/WS318FB3AB-E1D1-40f7- 9FD9-BB04A6F6A465.html#WSbaf9cd7d26a2eabf53ab041041081290f-7fe8
