Visualart.be
Annoying popups while previewing CS6
May 13, 2012 4:31 PM
Hi, in my workflow I usually start compositing before my 3D renders are finished. Now in CS6 apparently when I preview a part of the sequence I get constant popups when a new frame is rendered saying the sequence has X missing frames (due 3D rendering on a farm some frames are rendered ahead of others).
I don't mind that AE checks wether there are new frames rendered and updates the length of the imported footage but it shouldnt halt my previews while trying to watch them.
Is there an option to turn this feature off somewhere ?
kind regards
    May 12, 2012 7:46 PM   in reply to Visualart.be
    Not sure if there's a way to turn it off.
    Here's what I would do:
    Import a rendered frame and composite using just that one frame.  Don't check "image sequence"
    When your render's done, replace the footage with file, and then select your image sequence.
    May 14, 2012 12:02 AM   in reply to Visualart.be
    You could just create a dummy sequence and then let the renderer overwrite those dummy files? Not saying that you should have to do this, as AE's sequence handling indeed sucks big time in that regard, but it would be an appropriate workaround.
    Mylenium
    Jul 9, 2012 5:45 PM   in reply to Visualart.be
    You can file a feature request here: http://www.adobe.com/go/wish . More on how to give feedback: http://bit.ly/93d6NF
    Sep 27, 2012 2:28 PM   in reply to Visualart.be
    Exact same issue here and it is very annoying..
    There is no solution for this?
    Seriously limits workflow here too
