Introducing: Scale Strokes
May 7, 2012 2:54 AM
Tags: #script #ui #scale_strokes
Hi guys...the title says it all, based on the discussion on this thread
http://forums.adobe.com/message/4382760#4382760
get the script from here:
http://pastebin.com/6MKzZg4r
questions/comments? let me know
CarlosCanto
Replies 1 2 Previous Next
    May 7, 2012 3:38 AM   in reply to CarlosCanto
    Carlos,
    The script looks very nice and relevant.
    Do you download it (and if so, how), or copy the text and recreate it (also if so, how), and how far back does it work (there seems to be an abyss for other scripts between 10 and CS)?
    May 7, 2012 5:47 AM   in reply to CarlosCanto
    WOWWWWWWW!!!!
    Works like charm. Thanks God there are people like you here The best post I've seen on these forums!
    Saved the script with the name CarlosCanto_ScaleStrokesOnly
    Great job It is perfect already but If I'm allowed to make one suggestion it would be to make the Preview checked by default. I know it is following the Illustrator convention but you can make it better
    May 7, 2012 8:03 AM   in reply to CarlosCanto
    Thank you, Carlos.
    ... just replace the txt extension with jsx ...
    That is the answer, unfortunately: the x is the killer.
    May 7, 2012 8:32 AM   in reply to CarlosCanto
    Carlos,
    Long ago I downloaded the JET scripts (jsx files) and installed them, and Illy was completely paralyzed until I uninstalled them again.
    My investigation back then showed that I have to stick with scripts that are js (only) files.
    May 7, 2012 9:16 AM   in reply to Jacob Bugge
    Jacob,
    .jsx just associates it with ExtendScript Toolkit. It doesn't really have anything to do with the script itself.
    To try a script to see if it will run in AI10, try changing the extension to .js.
    It's still quite possible that a script may use functionality of the AI Javascript object model that didn't exist when AI10 shipped, or that has changed since. But the extension on the file does not necessarily mean there's anything in the script that AI 10 can't do. Note that when you download Carlos's script, its extension is .txt. That's all a Javascript is; a text file.
    JET
    May 7, 2012 2:58 PM   in reply to JETalmage
    James,
    Please forgive my lack of basic knowledge, but I have no clue how to do that in Windows XP. I have done something like it in the past, but that must be too long ago.
  • Mathias17
    Feb 20, 2012
    May 7, 2012 3:08 PM   in reply to Jacob Bugge
    Wait, you don't work for our Sales Dept, do you? K, no, I'm just kidding.
    Right Click > Rename   -OR-   F2 with the file selected. When you do it, you'll be warned that the file may become "unusable". Just ignore that.
    (You may have to first unhide file extensions for known filetypes in your Windows Exporer folder options.)
    Changing .JSX to .JS is just like changing a text file from .TXT to .HTML so that it's file association is changed. That's all the extension does - associate the file with a certain program(s). It has no effect on the file's contents.
    For fun, try changing an Illustrtaor .AI file's extension to .PDF, then open it up.
    May 7, 2012 3:21 PM   in reply to Mathias17
    Mathias,
    Neither way gives access to the extension: all that happens either way is that I get a file ending in .js.txt, and it still appears as a text file.
    May 7, 2012 3:38 PM   in reply to Jacob Bugge
    Jacob, you must be a trusting soul, not to have "Always Show File Extensions" on!
  • Mathias17
    Feb 20, 2012
    May 7, 2012 3:45 PM   in reply to Jacob Bugge
    It's entirely possible to name a file:
    Aunt Illy.pdf.txt
    In the above case, it's still a text file. ".PDF" is simply in the name (not extension) and is ignored. Only after the last period in the file's total name is the actual extension designated.
    You must verify you have 'Show File Extensions' turned on.
    Again, per the above case - without it, you don't see ".txt". So a file called: "Aunt Illy.pdf.txt" will look like "Aunt Illy.pdf" to you.
    Jongware, makes a great point. I recommend always keep file extensions showing. It's worth it.
    May 7, 2012 5:21 PM   in reply to CarlosCanto
    Well the script works great and I see no reason why Adobe should not pick this one up and incorporate it into the stroke panel.
    Thank you and well done.
    Cheers!
  • Mathias17
    Feb 20, 2012
    May 7, 2012 5:58 PM   in reply to CarlosCanto
    For the record, you can paste the textual contents of Carlos's [AKA Cronos of Tartarus] script into notepad and just save it as *.js  -OR-  *.jsx. It is just a text file afterall.
    (use the "Raw Paste Data" section at the bottom of the OP's linked page)
    But anyway, what this really adds is the real-time slider, and an easy percentage input, right? You just click in the Weight field and add *1.5 to scale to 150% if wanted. So "2pt*1.5" becomes 3pt.
    May 7, 2012 8:16 PM   in reply to Mathias17
    Very nice, Carlos.
    By the way, you are exceeding the limit:
    May 7, 2012 10:07 PM   in reply to tromboniator
    BTW it works in CS 6 and even takes on the CS interface.
  • Pierre Courtejoie
    Jan 11, 2006
    May 8, 2012 1:41 AM   in reply to Jacob Bugge
    Jacob. On windows, do browse to a folder. On Vista and 7, you might need to click on ALT to show the menus.
    There, click on Tools>Folder Options>View and uncheck "Hide extensions for known file types" I do it as a security measure also, otherwise, I don't know what I'm clicking on.
    May 8, 2012 3:19 AM   in reply to Pierre Courtejoie
    With tooltip....
    Without...
    CS6 / Mac
    May 8, 2012 3:46 AM   in reply to Mathias17
    Thank you very much, Mathias, and Pierre.
    Indeed. I finally found it in the Control Panel, after overlooking the option in the Tools dropdown.
    Unfortunately, Carlos:
    And Theunis,
    Indeed.
  • Mathias17
    Feb 20, 2012
    May 8, 2012 7:36 AM   in reply to CarlosCanto
    Hi Mathias, not really...well, for a Selection of 1, yes, or for multiple selections that will end with a uniform line weight. But the script works best with multiple selections with multiple line weights, all strokes will scale proportionally.
    Oh! Ok, yeah great!
    I've failed to say thanks for this, so far. So, thanks for makin' it!
    May 8, 2012 6:56 AM   in reply to CarlosCanto
    CS6 Screenshot
    I see Scott already did post a screenshot he's a traditionlist and made his lighter.
    May 8, 2012 9:15 AM   in reply to CarlosCanto
    Carlos – Firefox 13 (beta)
    edit: It's the same in Safari. Mac 10.6.8
    May 8, 2012 9:24 AM   in reply to CarlosCanto
    This is just to say GREAT job Carlos!
    works fine on Windows 7
    May 8, 2012 2:21 PM   in reply to Jacob Bugge
    Jacob,
    talking about using dialogs in conjunction with Javascripts in AI 10 you are clearly lost.
    CS 1 was the first version that introduced that capability.
    You're lost.
    May 8, 2012 2:30 PM   in reply to Kurt Gold
    You're lost.
    I know, Kurt.
    May 9, 2012 11:18 AM   in reply to CarlosCanto
    Carlos,
    Thank you for the offer, but I have no specific need for it.
    May 12, 2012 9:11 PM   in reply to CarlosCanto
    Hi Carlos, I have tried to modify your script to use a "palette" UI. It now looks like below:
    I don't know it's useful or not. Anyway, here is the link: http://pastebin.com/3jZ0PjKk
    May 13, 2012 6:02 AM   in reply to moluapple
    Moluapple,
    Very useful indeed! As I mentioned in the thread that gave rise to this, a palette version would be much more elegant; and it is. With your palette version, the flickering from the redraw is gone, so the slider works like a slider should. You can change the selection without dismissing the window.
    Moreover, though, I now (at long last) have an example of a functioning AI javascript palette--something I've been looking for ever since first dinking around with AI javascript dialogs.
    (I've run this in CS3, by the way, so it works at least that far back.)
    Thanks.
    JET
    May 13, 2012 7:00 AM   in reply to JETalmage
    You are welcome JETalmage, it's me the one need to say thanks, I learn a lot from you in this forum.
  • Mathias17
    Feb 20, 2012
    May 13, 2012 7:39 AM   in reply to moluapple
    Excellent, moluapple. Thanks for doing that.
1 2 Previous Next
Actions
