Encore CS5.1 menu library cleared when Encore CS6 menu library installed
May 12, 2012 4:01 AM
When I installed the Encore functional content (menu libs...) from the CS6 disk the menu libs were installed in Encore CS6 -and- the menu libraries were removed from Encore CS5.1. The menu libraries are not a separate load on Encore CS5.1. If this is expected how do I recover the lost menus?
Ed B
    May 12, 2012 8:06 PM   in reply to E Baldwin
    Not a good sign: see this thread:
    http://forums.adobe.com/thread/1002454
    May 13, 2012 1:30 AM   in reply to E Baldwin
    The solution to this issue would be - copy the cs6 library from C:\Program Files\Adobe\Adobe Encore CS6\Library and place it at another loacation and rename it.
    Now uninstall the CS6 Content and reinstall the 5.1 FC using the disc or the downloded FC you have. In this way you will recover back your 5.1 FC and can also use the 6.0 FC by pointing Encore to its location. I tried it and this works
    And this problem will no longer be faced once the downloadble version of CS6 FC will be available.
    see thread -http://forums.adobe.com/thread/1002454?tstart=0
