After Effects Text Problem
May 13, 2012 11:45 AM
Tags: #problem #after #effects #text
Ok so I am new to after effects, but this is such a simple conlfict but I cannot figure it out. When I create a text box and write something and I want to click enter to start a new line, it goes back behind what I already wrote. It wont form a line under the text like I want it to.   I want to do this >>
Text
Text
Text
But I cant. Please help.
    May 13, 2012 11:49 AM   in reply to Kyle D. Fisher
    Check your settings for line spacing, baseline shift and so on. Sounds liek you set them too odd values and every line renders on top of the other.
    Mylenium
    May 13, 2012 1:09 PM   in reply to Kyle D. Fisher
    Actually, you just need to drill down.
    The fastest way to reveal all keyframes is to select desired layer and press U.
    See more help on keyframes.
    May 13, 2012 5:07 PM   in reply to Fuzzy Barsik
    Since you're new to After Effects, I strongly recommend that you begin here are work your way through the basic getting-started materials:
    "Getting started with After Effects"
    Doing so will save a lot of confusion and headaches later.
