wing2012
i share computer with wife.  We each have a nook.  how do i authorize each of us on one computer?
May 13, 2012 3:01 PM
Tags: #activation #adobe_digital_editions
I need to authorize 2 users on same shared computer (separate win 7 signons) for 2 Nooks.  How can I do this?
thanks
    May 13, 2012 7:32 PM   in reply to wing2012
    If you check the ADE HELP FAQ's (F1 key when ADE is in Library or Reading
    mode), you'll see the way to change users under 'Authorize/deauthorize'.
    It's relatively simple, involving some command keys.   You can use this
    method to switch between you two.
    Hope this helps!
    May 13, 2012 10:39 PM   in reply to wing2012
    You can decide to either
    1) Share the same AdobeID  (which doesn't have to be the same as your B&N ID)
    or
    2.) Have different User Accounts on your computer (and authorize ADE on your OS User Accoutn with your AdobeID).
    May 14, 2012 8:35 PM   in reply to wing2012
    ADE stores the authorization on a per OS user basis, so as long as there are two seperate OS user, this will work.
    I would suggest narrowing down the problem by getting one nook to work with one account.
    Assuming you start with your wife's account:
    Start with making sure ADE is authorized to the correct account for the OS user (you can check this in the Library menu -> Authorize Computer),
    If it's not then you can deactivate ADE by using Ctrl (Cmd on Mac) Shift D, and then relaunch with the correct AdobeID.
    Make sure you can view content.
    Then make sure you can copy content your wife's nook.
    The make sure your wife's nook can view the content.
    If you can't then you may need to deactivate and reactivate the nook, using Ctrl (Cmd on Mac) Shift E
    After that's working, and only after that's working, log out of the OS user, log in with your ID and lather/rinse repeat with your nook.
    Afer you are finished with your account - then go back and double check that your wifes account/ADE/Nook are all still working and you should still be good to go.
    p.s. Your problem with #1 is expected if you already have different ADE IDs that you have content authorized to, and you've copied the wrong content to the wrong nook.
    pps - Just to make sure - content purchased from B&N does not work in ADE 1.7.2 you will need to use either:
    - Nook for Mac/PC
    - NookStudy for Mac/PC
    or
    - ADE 1.8.2 (currently in public beta at labs.adobe.com)
