flashprotweaker1
what in the world is with flash pro 6 !
May 13, 2012 8:06 PM
okay - as soon as i loaded my code into the new version
(i actually tried to re-download FLASH5.5 from last week
because the FONT embedding was not working - i believe
someone left out the **** module that Font attempts to
access and that fonts dont work at all with flash 55? i
tried every method on every site and have had fonts
working before in flash5/as3 and trust me it was not
going to work without loading something in FLEX even
though i am not using flex, and apparently it was not
there)
sooo i tried to re-download to see if i accidentally did
not install it as an option though all i remember as an
option was unchecking the AIR items
and i was forced to download PRO 6
so!
now when i compile i can tell you are doing more ecmia
compliance and that you are actually doing reverse tracebacks
(if not three nested layers of reverse tracebacks)
but here's the thing - my code will not function in any way and
will not give me any kind of sane error reporting in any way at
all to have any idea whatsoever what is going on
so!
i am pretty sure i hit an actual bug in your stack and that it
fails in the engine and does not actually get caught because
it is an actual bug
as far as i know you MIGHT be able to recreate the problem
by attempting to use a dynamic type class with a static structure
inside of it then create a static instance of that class within
the class definition - it is a basic paradigm i am not going to
get into naming it but it is very casual and very easy and allows
you to do an engine driver without putting too much cruft in
so when you define the class, let's say a simple class
(this is psuedo-code)
public class actionizer {
     public static var myAction = new actionizer("lemmings");
     public function actionizer () {
          trace("test");
then depending if you are hitting the static part (hey static
is there for a reason!) - you go in and out of referencing the
static parts or the actual instance, if you want to refer to
one or the other in terms of a dictionarized type of rosterizer
this is convenient for multi-screen systems where you want
one engine on one screen and the other engine on the other
screen and want to access static methods and stores for
both of them without having to be too long winded about it
if you need to deploy it for a client in 2 months for a comdex
convention and absolutely need the same "engine" and at
a minimum two screens to display what you are not going
to repeat throughout twenty actionscript files while not
contaminating the graphic designers and other interface
experts
now back in the main artillery loader you call up a bunch
of your routines like so (also psuedo-code);
import actionizer;
import tokenizer;
import lemmingizer;
import interfacers;
now this works because you add everything into the library
include directions in the actionscript3 properties so that it
will seek / hunt into the sub-directories so you can keep
sane workgroup control
so that gives you "global" (i am also hesitant to use that
word) access to everything you imported, though that does
NOT work with flash internals, because of the basic engine
design --- which is probably what i am getting at
in my actionizer i am not able to hit the includes my libraries
nooootttttttthinnnnnnggggggggg
lofl.
i have eighteen years of coding experience and i know how
the errors work and i tried a few other renders and compiles
and things so i am prettttty sure i actually hit an uncaught-error
in your stack due to static subclassing a static type
now this is because all of the usages of include and library files
are teccchnically visa vis static
so if you mess around a bit (there is no way i can send you
my code, i work in gaming and i have an NDA and am not
allowed to pass it on and i might be toting this code around
for the next eight to twelve years and i'd basically have to
send you the engine to get it to you
but i am prettttty sure since my code only has about two
hundred lines at the moment that you can easily recreate it
and what you get is a reverse traceback where all of the
errors are sorted in opposite order from the last error
to the first error with the first error displayed as a different
run and i think its at least two or three sets of errors,
but the last set is DEFINITELY printing out the line
numbers in reverse meaning its hitting a hardcore reverse
lookup and i am doubting that is a "new" feature of flash pro 6
so i am pretty sure there is nothing i can possibly do to fix
my code and i will be sitting here staring at it because i cant
download flash pro 55 - because trust me i can not change a
line nor add lines nor do anything whatsoever to get the
architecture behavior to change - and its not throwing errors
in any of the other classes and to be completely honest!!
if i cancel out every single reference to importing the "affected
file" -- it still hits it!!!!! lol. i mean i commented out every reference
to it - its not a lot of code - and its still going into the library and
include directory and nailing the **** thing
d:
let me know if you need any help or further comments i am
pretty sure you can recognize the way the error is printing out
in reverse as a technical administration engine core stack problem
so i can give you more parts of the sembelence of the code to
re-create it so you can trip the error in your main compiler
thanks and i'll be in touch - right now im like doh coz there aint
a thing i can do to this code to get over the hurdle , and im not
even being obstinant about that lofl
