2nddark
Audio keeps breaking for the video created by Adobe After Effect CS 5.5
May 13, 2012 10:26 PM
Tags: #audio #render #after_effects_cs5 #after_effects_cs5.5
I created a video using Adobe After Effect CS 5.5 and imported a MP3 file to the time line -
After rendering the video to a movie with .avi format, the audio keeps breaking during the show time.
basically the audio stops during the video and then starts again, stops and then starts again - and
it is really annoying.
I tried to change it from 16 bit to 8bit and 32 bit but nothing changed -
really appreciate any help, thanks
Here is some info about the video :
----Video----
Frame width : 1280
Frame height : 720
Data rate :    552978 kbps
Total bitrate: 554389 kbps
Frame rate: 25 frames /seconds
---- Audio---
Bit rate: 1411 kbps
Channels: 2
Audio sample rate: 44 kHz
    May 13, 2012 10:52 PM   in reply to 2nddark
    The flaw is here:
    Convert it to a WAV.
    Mylenium
    May 13, 2012 11:08 PM   in reply to 2nddark
    Do a little generic research on video compression, CoDecs and formats. that's nothing anyone can explain in 5 minutes. If the audio plays fine in your MP4 file, then it could be merely a data rate issue with wjhatever settings you chose for your AVI, but really, do a little reading and come back with more specific questions after that.
    Mylenium
