XML Data Search
May 11, 2012 7:27 AM
Tags: #cs5.5 #xml #actionscript3
I need to be able to use as3 to search through my XML file and populate dynamic text field with certain data. For example if this were my xml:
<firstperiod>
     <person>
          <name>Last, First</name>
          <grade1> 98 </grade1>
          <grade2> 87</grade2>
          <grade3> 62 </grade3>
          <grade4> 93 </grade4>
          <grade5> 96 </grade5>
     </person>
     <person2>
     </person2>
</firstperiod>
Then I may want to search for the highest grade and fill in a dynamic text field, or maybe the second highest grade and pull that data.  How could I do this?
    May 11, 2012 7:44 AM   in reply to Claunchster
    that's not a particularly good use of xml
    you might want to consider using something like this instead
    <period type="first">
              <person>
                        <grade type="1"> 98 </grade>
                        <grade type="2"> 87 </grade>
                        <grade type="3"> 62 </grade>
                        <grade type="4"> 93 </grade>
                        <grade type="5"> 96 </grade>
              </person>
              <person>
                        <grade type="1"> 89 </grade>
                        <grade type="2"> 78 </grade>
                        <grade type="3"> 26 </grade>
                        <grade type="4"> 39 </grade>
                        <grade type="5"> 69 </grade>
              </person>
    </period>;
    May 11, 2012 7:48 AM   in reply to Claunchster
    well I'm not particularly good either but I'll try
    <person> and <person2> are representing the same data therefore they should be represented by the same tag
    similarly for grade1 - 5
    if you need to differentiate between different grades they should have a property, like subject, or test so you know which subject or test the grades were for (I chose type in the example I gave just to be a bit more generic)
    similarly i changed firstperiod to period, because first implies there will be more and they are all periods so again i gave them a property so you could tell which one was first period and so on
    May 11, 2012 7:55 AM   in reply to _spoboyle
    in answer to your original question this might point you in the right direction
    package
              import flash.display.Sprite;
              public class Main extends Sprite
                        private static const xml:XML =
                                            <person>
                                            </person>
                                            <person>
                                            </person>
                                  </period>;
                        public function Main()
                                  var first:int = int.MIN_VALUE;
                                  var second:int = int.MIN_VALUE;
                                  var grades:XMLList = xml.descendants("grade");
                                  for each (var grade:XML in grades)
                                            var gradeValue:int = parseInt(grade);
                                            if (gradeValue > first)
                                                      second = first;
                                                      first = gradeValue;
                                            else if (gradeValue > second)
                                                      second = gradeValue;
                                  trace("highest: " + first);
                                  trace("second highest: " + second);
    May 14, 2012 2:16 AM   in reply to Claunchster
    I don't really work in AS2 so you might get a better response on the AS2 forum but this is something i knocked up that seems to work
    grades.xml
                        <person>
                        </person>
                        <person>
                        </person>
    </period>
    <period type="second">
                        <person>
                                              <grade type="1"> 56 </grade>
                                              <grade type="2"> 49 </grade>
                                              <grade type="3"> 78 </grade>
                                              <grade type="4"> 99 </grade>
                                              <grade type="5"> 43 </grade>
                        </person>
                        <person>
                                              <grade type="1"> 24 </grade>
                                              <grade type="2"> 56 </grade>
                                              <grade type="3"> 73 </grade>
                                              <grade type="4"> 81 </grade>
                                              <grade type="5"> 55 </grade>
                        </person>
    </period>
    as in frame 1 of fla
    trace("start");
    var xml:XML = new XML();
    xml.ignoreWhite = true;
    xml.load("grades.xml");
    xml.onLoad = xmlLoaded;
    function xmlLoaded(loaded)
              if (loaded)
                        var grades:Array = getGrades(this);
                        var first:Number = Number.MIN_VALUE;
                        var second:Number = Number.MIN_VALUE;
                        for (var i:Number = 0; i < grades.length; i++)
                                  var grade:Number = grades[i];
                                  if (grade > first)
                                            second = first;
                                            first = grade;
                                  else if (grade > second)
                                            second = grade;
                        trace("first: " + first);
                        trace("second: " + second);
    function getGrades(xml:XML):Array
              var gradeValues:Array = new Array();
              var periods:Array = xml.childNodes;
              for (var i:Number = 0; i < periods.length; i++)
                        var period:XMLNode = periods[i];
                        var people:Array = period.childNodes;
                        for (var j:Number = 0; j < people.length; j++)
                                  var person:XMLNode = people[j];
                                  var grades:Array = person.childNodes;
                                  for (var k:Number = 0; k < grades.length; k++)
                                            var grade:XMLNode = grades[k];
                                            if (grade.nodeName == "grade")
                                                      var gradeValue:Number = parseInt(grade.firstChild.toString());
                                                      gradeValues.push(gradeValue);
              return gradeValues;
