Introducing: Scale Strokes
May 7, 2012 2:54 AM
Tags: #script #ui #scale_strokes
  Latest reply: Mathias17, May 15, 2012 10:17 AM
Replies 1 2 Previous Next
    May 13, 2012 6:40 PM   in reply to CarlosCanto
    Carlos,
    I think I learned this from the Adobe Illustrator CS3 FlashPanel Sample, and I have using this method for quite a long time.
    May 14, 2012 2:43 AM   in reply to CarlosCanto
    Hi all,
    That's interesting, the doc is using a bridgeTalk but you should be able to call the function directly. Or this is either related to Illustrator or CS3- versions. I did use a few ScriptUI/SWF projects with ExternalInterface but never needed to use a bridgeTalk. Anyway I am very fond of theses technologies
    Best,
    Loic
    hht://www.loicaigon.com
    hht://www.loicaigon.com/blog
    May 14, 2012 5:18 AM   in reply to Loic_aigon
    Hi Loic,
    With Indesign that's true, but sadly not Illustrator, even with CS6.
    May 14, 2012 5:21 AM   in reply to moluapple
    Hi Mark,
    Ok I ignored it thx for the info !
    Loic
  • Mathias17
    Feb 20, 2012
    May 15, 2012 8:05 AM   in reply to moluapple
    Can I recommend a slight revision to this?
    Enable Up and Down arrow keys when caret is in the Scale text field, which would increase or decrease the Scale value by 1. Also, Shift+Up and Shift+Down as well (which would bump the percent by 10% of course).
    May 15, 2012 9:15 AM   in reply to Mathias17
    Yes, if its possible to implement Mathias suggestion, this will be great. Meanwhile the closest alternative is to press and hold with the mouse the left or right buttons of the scroll bar. However I noticed that doing so with the panel will change the value but not give a real time feedback of the change and will update the screen redraw after releasing the mouse while ith the original non-modal window it does update in real time feedback but it flickers.
    Nevertheless, great job guys, you rock!   I find this script as a better alternative to a assign a precise stroke weight even when using a single path. The predefined increments available in the Illustrator's Stroke panel are not very practical for me. I often need fine tuning of strokes in the range of 0.25 to 3 points and I end up spending a lot of time typing trial and error values in that range to get precisely the desired weight. Your script makes this much easier and interactively.
    May 15, 2012 10:15 AM   in reply to CarlosCanto
    That will be great Carlos, very much appreciated.
  • Mathias17
    Feb 20, 2012
    May 15, 2012 10:17 AM   in reply to CarlosCanto
    Very cool, Carlos. You're softening some of the CS6 dismay with this one.
1 2 Previous Next
Actions
