In the last week I upgraded and downloaded the NEW version of Photoshop extended and for the first few days it performed OK.
Today it has started to do something that I have never come across before, when I go to save a file, ie save a .psd file as a .jpeg file it says it will save it as a .dcm and I can only create a .jpeg file if I go down the list of file extensions and choose a totally unrelated file extension.
Can anyone please help me solve this problem.
regards
David May
Hello!
You need to remove the link to the previous version's plug-in folder that you set in your preferences.
You need to point to a folder where you save your additional (third-party/non-adobe) plug-ins, and not the root of Photoshop Cs5's plug-in, as that imported the file formats as well, messing up your saving process.
As long as you're loading the file format plugins from a previous version of Photoshop - you're going to continue having problems with the file format listing in the save dialog.
Turn off the optional plugins folder preference, and delete any Adobe plugins that you copied to the CS6 plugins folder.
Chris
I have done both of these searches and in the Photoshop help-> System info I could not see any reference to file format at all.
I am attaching that info.
Adobe Photoshop Version: 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00) x64
Operating System: Mac OS 10.7.4
System architecture: Intel CPU Family:6, Model:42, Stepping:7 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, HyperThreading
Physical processor count: 4
Logical processor count: 8
Processor speed: 3400 MHz
Built-in memory: 8192 MB
Free memory: 4863 MB
Memory available to Photoshop: 7246 MB
Memory used by Photoshop: 70 %
Image tile size: 1024K
Image cache levels: 4
OpenGL Drawing: Enabled.
OpenGL Drawing Mode: Advanced
OpenGL Allow Normal Mode: True.
OpenGL Allow Advanced Mode: True.
OpenGL Allow Old GPUs: Not Detected.
OpenGL Version: 2.1 ATI-7.18.18
OpenCL Version:
Video Card Vendor: ATI Technologies Inc.
Video Card Renderer: ATI Radeon HD 6970M OpenGL Engine
Display: 1
Main Display
Display Depth:= 32
Display Bounds:= top: 0, left: 0, bottom: 1440, right: 2560
Video Renderer ID: 16915205
Video Card Memory: 2048 MB
Video Rect Texture Size: 16384
Serial number: 90149920358234059938
Application folder: Hard Drive:Applications:Adobe Photoshop CS6:
Photoshop scratch has async I/O enabled
Scratch volume(s):
Startup, 1.82T, 1.58T free
Required Plug-ins folder: Hard Drive:Applications:Adobe Photoshop CS6:Adobe Photoshop CS6.app:Contents:Required:
Primary Plug-ins folder: Hard Drive:Applications:Adobe Photoshop CS6:Plug-ins:
Additional Plug-ins folder: not set
Installed components:
adbeape.framework adbeape 3.3.8.19346 66.1025012
AdbeScriptUIFlex.framework AdbeScriptUIFlex 6.2.29.18602 66.490082
adobe_caps.framework adobe_caps 6.0.29.0 1.276181
AdobeACE.framework AdobeACE 2.19.18.19243 66.492997
AdobeAGM.framework AdobeAGM 4.26.17.19243 66.492997
AdobeAXE8SharedExpat.framework AdobeAXE8SharedExpat 3.7.101.18636 66.26830
AdobeAXEDOMCore.framework AdobeAXEDOMCore 3.7.101.18636 66.26830
AdobeBIB.framework AdobeBIB 1.2.02.19243 66.492997
AdobeBIBUtils.framework AdobeBIBUtils 1.1.01 66.492997
AdobeCoolType.framework AdobeCoolType 5.10.31.19243 66.492997
AdobeCrashReporter.framework AdobeCrashReporter 6.0.20120201
AdobeExtendScript.framework AdobeExtendScript 4.2.12.18602 66.490082
AdobeJP2K.framework AdobeJP2K 2.0.0.18562 66.236923
AdobeLinguistic.framework 17206
AdobeMPS.framework AdobeMPS 5.8.0.19463 66.495174
AdobeOwl.framework AdobeOwl 4.0.93 66.496052
AdobePDFL.framework AdobePDFL 10.0.1.18562 66.419471
AdobePDFSettings.framework AdobePDFSettings 1.4
AdobePIP.framework AdobePIP 6.0.0.1654
AdobeScCore.framework AdobeScCore 4.2.12.18602 66.490082
AdobeUpdater.framework AdobeUpdater 6.0.0.1452 "52.338651"
AdobeXMP.framework AdobeXMPCore 66.145661 66.145661
AdobeXMPFiles.framework AdobeXMPFiles 66.145661 66.145661
AdobeXMPScript.framework AdobeXMPScript 66.145661 66.145661
ahclient.framework ahclient 1.7.0.56
aif_core.framework AdobeAIF 3.0.00 62.490293
aif_ocl.framework AdobeAIF 3.0.00 62.490293
aif_ogl.framework AdobeAIF 3.0.00 62.490293
AlignmentLib.framework xcode 1.0.0.1
amtlib.framework amtlib 6.0.0.75
boost_date_time.framework boost_date_time 6.0.0.0
boost_signals.framework boost_signals 6.0.0.0
boost_system.framework boost_system 6.0.0.0
boost_threads.framework boost_threads 6.0.0.0
Cg.framework NVIDIA Cg
CIT.framework CIT 2.0.5.19287 145486
data_flow.framework AdobeAIF 3.0.00 62.490293
dvaaudiodevice.framework dvaaudiodevice 6.0.0.0
dvacore.framework dvacore 6.0.0.0
dvamarshal.framework dvamarshal 6.0.0.0
dvamediatypes.framework dvamediatypes 6.0.0.0
dvaplayer.framework dvaplayer 6.0.0.0
dvatransport.framework dvatransport 6.0.0.0
dvaunittesting.framework dvaunittesting 6.0.0.0
dynamiclink.framework dynamiclink 6.0.0.0
FileInfo.framework FileInfo 66.145433 66.145433
filter_graph.framework AdobeAIF 3.0.00 62.490293
hydra_filters.framework AdobeAIF 3.0.00 62.490293
ICUConverter.framework ICUConverter 3.61 "gtlib_3.0" "." "16615"
ICUData.framework ICUData 3.61 "gtlib_3.0" "." "16615"
image_compiler.framework AdobeAIF 3.0.00 62.490293
image_flow.framework AdobeAIF 3.0.00 62.490293
image_runtime.framework AdobeAIF 3.0.00 62.490293
LogSession.framework LogSession 2.1.2.1652
mediacoreif.framework mediacoreif 6.0.0.0
PlugPlug.framework PlugPlug 3.0.0.383
UpdaterNotifications.framework UpdaterNotifications 6.0.0.24 "6.0.0.24"
wrservices.framework
Required plug-ins:
3D Studio 13.0 20120315.r.428 2012/03/15:21:00:00 ©2006-2012 Adobe Systems Incorporated - from the file “U3D.plugin”
Accented Edges 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Adaptive Wide Angle 13.0, Copyright © 2012 Adobe Systems Incorporated - from the file “Adaptive Wide Angle.plugin”
Angled Strokes 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Average 13.0 20120315.r.428 2012/03/15:21:00:00 ©1993-2012 Adobe Systems Incorporated - from the file “Average.plugin”
Bas Relief 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
BMP 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Camera Raw 6.7 (339), Copyright © 2012 Adobe Systems Incorporated - from the file “Camera Raw.plugin”
Chalk & Charcoal 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Chrome 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Cineon 13.0 20120315.r.428 2012/03/15:21:00:00 ©2002-2012 Adobe Systems Incorporated - from the file “Cineon.plugin”
Clouds 13.0 20120315.r.428 2012/03/15:21:00:00 ©1993-2012 Adobe Systems Incorporated - from the file “Clouds.plugin”
Collada DAE 13.0 20120315.r.428 2012/03/15:21:00:00 ©2006-2012 Adobe Systems Incorporated - from the file “U3D.plugin”
Color Halftone 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Colored Pencil 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
CompuServe GIF 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Conté Crayon 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Craquelure 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Crop and Straighten Photos 13.0 20120315.r.428 2012/03/15:21:00:00 ©2003-2012 Adobe Systems Incorporated - from the file “CropPhotosAuto.plugin”
Crop and Straighten Photos Filter 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Crosshatch 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Crystallize 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Cutout 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Dark Strokes 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
De-Interlace 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Dicom 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “dicom.plugin”
Difference Clouds 13.0 20120315.r.428 2012/03/15:21:00:00 ©1993-2012 Adobe Systems Incorporated - from the file “Clouds.plugin”
Diffuse Glow 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Displace 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Dry Brush 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Eazel Acquire 13.0 20120315.r.428 2012/03/15:21:00:00 ©1997-2012 Adobe Systems Incorporated - from the file “EazelAcquire.plugin”
Embed Watermark NO VERSION - from the file “DigiSign.plugin”
Enable Async I/O 13.0 20120315.r.428 2012/03/15:21:00:00 © 2004-2012 Adobe Systems Incorporated - from the file “Enable Async IO.plugin”
Entropy 13.0 20120315.r.428 2012/03/15:21:00:00 ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
Extrude 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
FastCore Routines 13.0 20120315.r.428 2012/03/15:21:00:00 ©1990-2012 Adobe Systems Incorporated - from the file “FastCore.plugin”
Fibers 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Film Grain 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Filter Gallery 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Flash 3D 13.0 20120315.r.428 2012/03/15:21:00:00 ©2006-2012 Adobe Systems Incorporated - from the file “U3D.plugin”
Fresco 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Glass 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Glowing Edges 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Google Earth 4 KMZ 13.0 20120315.r.428 2012/03/15:21:00:00 ©2006-2012 Adobe Systems Incorporated - from the file “U3D.plugin”
Graphic Pen 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Halftone Pattern 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
HDRMergeUI 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “HDRMergeUI.plugin”
IFF Format 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Ink Outlines 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
JPEG 2000 13.0 20120315.r.428 2012/03/15:21:00:00 ©2001-2012 Adobe Systems Incorporated - from the file “JPEG2000.plugin”
Kurtosis 13.0 20120315.r.428 2012/03/15:21:00:00 ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
Lens Blur 13.0, Copyright © 2002-2012 Adobe Systems Incorporated - from the file “Lens Blur.plugin”
Lens Correction 13.0, Copyright © 2002-2012 Adobe Systems Incorporated - from the file “Lens Correct.plugin”
Lens Flare 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Liquify 13.0, Copyright © 2001-2012 Adobe Systems Incorporated - from the file “Liquify.plugin”
Matlab Operation 13.0 20120315.r.428 2012/03/15:21:00:00 ©1993-2012 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
Maximum 13.0 20120315.r.428 2012/03/15:21:00:00 ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
Mean 13.0 20120315.r.428 2012/03/15:21:00:00 ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
Measurement Core 13.0 20120315.r.428 2012/03/15:21:00:00 ©1993-2012 Adobe Systems Incorporated - from the file “MeasurementCore.plugin”
Median 13.0 20120315.r.428 2012/03/15:21:00:00 ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
Mezzotint 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Minimum 13.0 20120315.r.428 2012/03/15:21:00:00 ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
MMXCore Routines 13.0 20120315.r.428 2012/03/15:21:00:00 ©1990-2012 Adobe Systems Incorporated - from the file “MMXCore.plugin”
Mosaic Tiles 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Neon Glow 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Note Paper 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
NTSC Colors 13.0 20120315.r.428 2012/03/15:21:00:00 ©1993-2012 Adobe Systems Incorporated - from the file “NTSC Colors.plugin”
Ocean Ripple 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Oil Paint 13.0, Copyright © 2011 Adobe Systems Incorporated - from the file “Oil Paint.plugin”
OpenEXR 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Paint Daubs 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Palette Knife 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Patchwork 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Paths to Illustrator 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
PCX 13.0 20120315.r.428 2012/03/15:21:00:00 ©1989-2012 Adobe Systems Incorporated - from the file “PCX.plugin”
Photocopy 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Photoshop 3D Engine 13.0 20120315.r.428 2012/03/15:21:00:00 ©2006-2012 Adobe Systems Incorporated - from the file “Photoshop3DEngine.plugin”
Picture Package Filter 13.0 20120315.r.428 2012/03/15:21:00:00 ©1993-2012 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
Pinch 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Pixar 13.0 20120315.r.428 2012/03/15:21:00:00 ©1989-2012 Adobe Systems Incorporated - from the file “Pixar.plugin”
Plaster 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Plastic Wrap 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
PNG 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Pointillize 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Polar Coordinates 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Portable Bit Map 13.0 20120315.r.428 2012/03/15:21:00:00 ©1989-2012 Adobe Systems Incorporated - from the file “PBM.plugin”
Poster Edges 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Radial Blur 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Radiance 13.0 20120315.r.428 2012/03/15:21:00:00 ©2003-2012 Adobe Systems Incorporated - from the file “Radiance.plugin”
Range 13.0 20120315.r.428 2012/03/15:21:00:00 ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
Read Watermark NO VERSION - from the file “DigiRead.plugin”
Reticulation 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Ripple 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Rough Pastels 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Save for Web 13.0, Copyright © 1999-2012 Adobe Systems Incorporated - from the file “Save for Web.plugin”
ScriptingSupport 13.0, Copyright © 2012 Adobe Systems Incorporated - from the file “ScriptingSupport.plugin”
Shear 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Skewness 13.0 20120315.r.428 2012/03/15:21:00:00 ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
Smart Blur 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Smudge Stick 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Solarize 13.0 20120315.r.428 2012/03/15:21:00:00 ©1993-2012 Adobe Systems Incorporated - from the file “Solarize.plugin”
Spatter 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Spherize 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Sponge 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Sprayed Strokes 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Stained Glass 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Stamp 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Standard Deviation 13.0 20120315.r.428 2012/03/15:21:00:00 ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
Sumi-e 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Summation 13.0 20120315.r.428 2012/03/15:21:00:00 ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
Targa 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Texturizer 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Tiles 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Torn Edges 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Twirl 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
U3D 13.0 20120315.r.428 2012/03/15:21:00:00 ©2006-2012 Adobe Systems Incorporated - from the file “U3D.plugin”
Underpainting 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Vanishing Point 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “VanishingPoint.plugin”
Variance 13.0 20120315.r.428 2012/03/15:21:00:00 ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
Water Paper 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Watercolor 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Wave 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Wavefront|OBJ 13.0 20120315.r.428 2012/03/15:21:00:00 ©2006-2012 Adobe Systems Incorporated - from the file “U3D.plugin”
Wireless Bitmap 13.0 20120315.r.428 2012/03/15:21:00:00 ©1989-2012 Adobe Systems Incorporated - from the file “WBMP.plugin”
ZigZag 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Optional and third party plug-ins:
Accented Edges 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
ADM 3.10x16, Copyright © 1987-2008 Adobe Systems Inc. All rights reserved. - from the file “AdobeADM.bundle”
Alien Skin Autolayer 3 NO VERSION - from the file “Alien Skin Autolayer 3.8li.plugin”
Alien Skin Autolayer 4 Autolayer 4.0.0.111 20098 Copyright © 2011 Alien Skin Software, LLC - from the file “Alien Skin Autolayer 4.8li.plugin”
Alien Skin Blow Up 3 Blow Up 3 3.0.0.628 19720 Copyright © 2011 Alien Skin Software, LLC - from the file “Alien Skin Blow Up 3 Automation.8li.plugin”
Angled Strokes 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Average 12.1x20110328 Re: Photoshop CS6 for Mc ©1993-2011 Adobe Systems Incorporated - from the file “Average.plugin”
Bas Relief 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Blemish Concealer Image Doctor 2 2.1.1.1107 18819 Copyright © 2007 Alien Skin Software, LLC - from the file “Image Doctor 2.plugin”
Blow Up Blow Up 3 3.0.0.628 19720 Copyright © 2011 Alien Skin Software, LLC - from the file “Alien Skin Blow Up 3 Photoshop.8bf.plugin”
BMP 12.0.2, Copyright © 2003-2010 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Bokeh Bokeh 2 2.0.1.442 19135 Copyright © 2010 Alien Skin Software, LLC - from the file “Alien Skin Bokeh 2.8bf.plugin”
Chalk & Charcoal 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Chrome 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Clouds 12.1x20110328 Re: Photoshop CS6 for Mc ©1993-2011 Adobe Systems Incorporated - from the file “Clouds.plugin”
Color Halftone 12.0.2, Copyright © 2003-2010 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Colored Pencil 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
CompuServe GIF 12.0.2, Copyright © 2003-2010 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Conté Crayon 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Craquelure 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Crop and Straighten Photos 12.1x20110328 Re: Photoshop CS6 for Mc ©2003-2011 Adobe Systems Incorporated - from the file “CropPhotosAuto.plugin”
Crop and Straighten Photos Filter 12.0.2, Copyright © 2003-2010 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Crosshatch 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Crystallize 12.0.2, Copyright © 2003-2010 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Cutout 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Dark Strokes 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
De-Interlace 12.0.2, Copyright © 2003-2010 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Difference Clouds 12.1x20110328 Re: Photoshop CS6 for Mc ©1993-2011 Adobe Systems Incorporated - from the file “Clouds.plugin”
Diffuse Glow 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Displace 12.0.2, Copyright © 2003-2010 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Dry Brush 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Dust and Scratch Remover Image Doctor 2 2.1.1.1107 18819 Copyright © 2007 Alien Skin Software, LLC - from the file “Image Doctor 2.plugin”
Eazel Acquire 12.1x20110328 Re: Photoshop CS6 for Mc ©1997-2011 Adobe Systems Incorporated - from the file “EazelAcquire.plugin”
Entropy 12.1x20110328 Re: Photoshop CS6 for Mc ©2006-2011 Adobe Systems Incorporated - from the file “statistics.plugin”
Exposure 4 Exposure 4 4.0.0.433 20126 Copyright © 2012 Alien Skin Software, LLC - from the file “Alien Skin Exposure 4 Photoshop.8bf.plugin”
Extrude 12.0.2, Copyright © 2003-2010 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Fibers 12.0.2, Copyright © 2003-2010 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Film Grain 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Filter Forge 3 NO VERSION - from the file “Filter Forge 3 universal x86.plugin”
Filter Gallery 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
FocalPoint 2 2.0.6, Copyright © 2011 onOne Software. All rights reserved. - from the file “FocalPointAutomation.plugin”
FocalPoint 2 Filter 2.0.6, Copyright © 2011 onOne Software. All rights reserved. - from the file “FocalPointFilter.plugin”
FocalPoint 2 Hidden NO VERSION - from the file “HiddenFilter.plugin”
FontExplorer X Pro 3.2.0, by HLW - from the file “FontExplorer X for Photoshop CS5.plugin”
Fresco 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Glass 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Glowing Edges 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Graphic Pen 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Halftone Pattern 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
HDRMergeUI 12.0, Copyright © 2003-2010 Adobe Systems Incorporated - from the file “HDRMergeUI.plugin”
IFF Format 12.0.2, Copyright © 2003-2010 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Ink Outlines 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
JPEG Repair Image Doctor 2 2.1.1.1107 18819 Copyright © 2007 Alien Skin Software, LLC - from the file “Image Doctor 2.plugin”
Kurtosis 12.1x20110328 Re: Photoshop CS6 for Mc ©2006-2011 Adobe Systems Incorporated - from the file “statistics.plugin”
Lens Blur 12.0, Copyright © 2002-2010 Adobe Systems Incorporated - from the file “Lens Blur.plugin”
Lens Correction 12.0.2, Copyright © 2002-2010 Adobe Systems Incorporated - from the file “Lens Correct.plugin”
Lens Flare 12.0.2, Copyright © 2003-2010 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Liquify 12.0.1, Copyright © 2001-2010 Adobe Systems Incorporated - from the file “Liquify.plugin”
Matlab Operation 12.1x20110328 Re: Photoshop CS6 for Mc ©1993-2011 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
Maximum 12.1x20110328 Re: Photoshop CS6 for Mc ©2006-2011 Adobe Systems Incorporated - from the file “statistics.plugin”
Mean 12.1x20110328 Re: Photoshop CS6 for Mc ©2006-2011 Adobe Systems Incorporated - from the file “statistics.plugin”
Measurement Core 12.1x20110328 Re: Photoshop CS6 for Mc ©1993-2011 Adobe Systems Incorporated - from the file “MeasurementCore.plugin”
Median 12.1x20110328 Re: Photoshop CS6 for Mc ©2006-2011 Adobe Systems Incorporated - from the file “statistics.plugin”
Mezzotint 12.0.2, Copyright © 2003-2010 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Minimum 12.1x20110328 Re: Photoshop CS6 for Mc ©2006-2011 Adobe Systems Incorporated - from the file “statistics.plugin”
Mosaic Tiles 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Multiprocessor Support 12.1x20110328 Re: Photoshop CS6 for Mc ©1990-2011 Adobe Systems Incorporated - from the file “MultiProcessor Support.plugin”
Neon Glow 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Note Paper 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
NTSC Colors 12.1x20110328 Re: Photoshop CS6 for Mc ©1993-2011 Adobe Systems Incorporated - from the file “NTSC Colors.plugin”
Ocean Ripple 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
OpenEXR 12.0.2, Copyright © 2003-2010 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Paint Daubs 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Palette Knife 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Patchwork 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Paths to Illustrator 12.0.2, Copyright © 2003-2010 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Photocopy 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Photoshop 3D Engine 12.1x20110328 Re: Photoshop CS6 for Mc ©2006-2011 Adobe Systems Incorporated - from the file “Photoshop3DEngine.plugin”
Picture Package Filter 12.1x20110328 Re: Photoshop CS6 for Mc ©1993-2011 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
Pinch 12.0.2, Copyright © 2003-2010 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Plaster 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Plastic Wrap 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
PNG 12.0.2, Copyright © 2003-2010 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Pointillize 12.0.2, Copyright © 2003-2010 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Polar Coordinates 12.0.2, Copyright © 2003-2010 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Poster Edges 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Radial Blur 12.0.2, Copyright © 2003-2010 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Range 12.1x20110328 Re: Photoshop CS6 for Mc ©2006-2011 Adobe Systems Incorporated - from the file “statistics.plugin”
Reduce Noise Neat Image v7.1.0 Pro plug-in for Photoshop, Copyright © 1999-2011 ABSoft. All rights reserved. - from the file “NeatImage.plugin”
Reticulation 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Ripple 12.0.2, Copyright © 2003-2010 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Rough Pastels 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Save for Web 12.0, Copyright © 1999-2010 Adobe Systems Incorporated - from the file “Save for Web.plugin”
Shear 12.0.2, Copyright © 2003-2010 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Skewness 12.1x20110328 Re: Photoshop CS6 for Mc ©2006-2011 Adobe Systems Incorporated - from the file “statistics.plugin”
Skin Softener Image Doctor 2 2.1.1.1107 18819 Copyright © 2007 Alien Skin Software, LLC - from the file “Image Doctor 2.plugin”
Smart Blur 12.0.2, Copyright © 2003-2010 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Smart Fill Image Doctor 2 2.1.1.
David May
And as you can see from that, you're still loading a LOT of duplicate plugins that you copied from Photoshop CS5.
Let's do this the easy way: turn off the "additional plugins folder" preference in Photoshop's preferences - it's not needed.
Now go delete EVERYTHING in the Photoshop CS6 plugins folder (it installs empty anyway).
I do not have the plugins still from the download as I copied my previous plugins into the plug in folder.
Is there a way that I can just get the cs6 plugins in a download.
I am a little annoyed about this, it has never happened to me before and I have had Photoshop since it's second version. In the future I will NOT avail myself of the download option, I thought I was saving time and money, but all this has done is caused ,a loss of both.
David May
Are you telling me you do not have the .dmg disk image of the CS6 installer you downloaded? ![]()
If that is the case and you need plug-ins contained in the Optional Plug-Ins folder, or the Goodies folder, and if somehow you have deleted those optional folders from your CS6 install, then the answer is yes, you'll have to download the disk image from Adobe again. The Adobe plug-ins are not available for downloading just by themselves.
In the case of third-party plug-ins, you need to get fresh, updated plug-ins from each vendor (such as Nik, OnOne, etc.).
Dave_May wrote:
…is there a way that I can just get the cs6 plugins in a download…
As I just said, no.
Dave_May wrote:
…a little annoyed about this… In the future I will NOT avail myself of the download option, I thought I was saving time and money, but all this has done is caused ,a loss of both…
Personally, I have always felt that not getting the physical install media in the box is a bad idea.
You didn't even burn your own install DVD from the downloaded dmg?
Ouch! But I'm sure you will next time. ![]()
Understand that we're users just like you. You are not addressing Adobe officially here. Even the Adobe engineers who volunteer their contributions here do so on their own time.
By the way, I'm assuming the CS6 final version indeed has those Optional Plug-ins or Goodies folders I referenced. I'm still using the beta, waiting for the process of claiming my complimentary CS6 final version to complete.
But, as Chris Cox has just told you, the required or normal plug-ins are already there, you have not deleted them.
Dave_May wrote:
…I cannot see a folder in Photoshop that is called "required", is it in the App folder or somewhere else?…
Dave,
Let me re-phrase that for you:
"The Adobe plugins are in the required folder" = The Adobe plug-ins that are required for your Photoshop CS6 to function, are already in the appropriate folder, as required. Better now?
Look, the whole Plug-ins folder situation in CS6 resulted from the fact that prior to CS6, there was a 'Plug-ins' folder hierarchy inside the Photoshop Folder that had both 3rd party and Adobe supplied plug-ins co-mingled in the same basic folder.
In the past that has caused problems because users had a tendency to install 3rd party plug-ins in the same folders as Adobe installed plug-ins.
In CS6, the thought was to simplify the folder structure so that Adobe installed plug-ins were "hidden" and 3rd party plug-ins could be installed in a simple 'Plug-ins' folder in the root of the Photoshop CS6 Folder.
Unfortunately, users didn't get the word...some freaked out when looking into the main 'Plug-ins' folder and not seeing all the main Adobe installed plug-ins decided to either copy an old Photoshop specific plug-ins folder into that folder (and found all sorts of undesirable results) or chose to click the option to include a separate folder as a legacy plug-ins folder in Preferences as an option–which is a really, REALLY bad idea unless you know exactly what you are doing–which few really do.
Bottom line?
If you have CS6, do NOT try to set CS5 or earlier 'Additional Plug-ins Folder' as the the source of 3rd party plug-ins unless you've already segregated 3rd party plug-ins from Adobe installed plug-ins
If you don't understand what I just wrote, then don't do ANYTHING other that downloading and installing, by regular installers, ANY 3rd party plug-ins...ok?
What I did was to remove all the plugins that I had copied from my CS5 plugins folder (I deleted them to the trash as I had the original in my CS5 plugins folder). I then moved one plugin at a time from my trash can back to my CS6 plugin folder. I would restart Photoshop CS6 and try the "Save as..." command. If it came up with the right extension for the associated file type I would leave that plugin in the new CS6 plugins folder. I would continue to move plugins back into the CS6 plugins folder one at a time, restart Photoshop and test to see if it was causing the problem. I don't know if it was the process of copying them back from my trash can or not copying them from the CS5 plugins folder but they pretty much all work as expected without having to reinstall all the plugins from the original installer. I can now use the "Save As..." command without trying to figure out what type of file type to select to get the correct extension and at the same time all the plugins that I use work as expected.
Thanks Chris
All sorted now.
I bet you are not the person to ask but here goes.
I downloaded and installed Adobe Camera Raw 7.1 and now I cannot see any of my lens that were available in the previous version, how can I sort this out?
I have been online and the place where there are profiles for cameras and lens, there is nothing that relates to the Nikon D800!
Regards
David May
