lost_keys
How to save my file, that I put into multitrack session, with changes what I did in there
May 14, 2012 4:09 AM
Tags: #save #adobe #audition #multitrack
Alright. I have a mission to make Audio CD from some tracks that are not consistent with each other. So I put my files into "track one" and I put on every ending of previous file an opening of subsequent file. It turned out something like fade-in/fade-out. So, is there any way to save my files in this possition separatly? I was doing this: save it all in a single mix and cut each song by itself. It's not very convenient, plus I'd like an even split. I hope you get the idea: to make MP3 files, which "flow" into each other. We need a more automatic way.
Thanks.
  • SteveG(AudioMasters)
    Oct 26, 2006
    May 14, 2012 11:26 AM   in reply to lost_keys
    Oh, no we don't - that's for Mickey Mouse software, and Audition isn't that.
    What you want to achieve is quite easy to do, but first you have to understand how the software works. If you put all your files separately into track one with overlaps, then you have created a multitrack session. If you save the session (an option in the files menu), then whatever you have done in the way of positioning gets saved, and you can close this and go back to it and change it any time you want. When you have everything in your session playing the way you want, then you can export this to a new, mixed-down file. All of the original files remain untouched, but there's now an extra file which represents the results of your work. And you don't want the result as an MP3 file either - you need the mixdown file to be a 16-bit, 44.1k stereo wav in order to make an audio CD.
    Oct 26, 2006
    May 14, 2012 3:14 PM   in reply to lost_keys
    Not quite. We call a cue file a cue list, and it just represents points in a file, or in fact in a multitrack session as well. What you would be saving though is a session file, and this contains every single bit of information about everything in the session - so if you put EQ, Volume changes, effects, whatever, it's all recalled, along with the position of every file or clip in it. Normally you'd put this session file in the same folder as the files in your session that it's calling (these are called 'assets'), so when you re-open the session, it looks exactly as it did when you set it up in the first place.
    May 14, 2012 3:23 PM   in reply to lost_keys
    After completing your mix in multitrack, you can create range markers by making a time-selection for each song positioning the end of your range in the middle of your cross-fade and pressing "M", then starting the next range selection at that position.
    When you have a range marker to represent each of your desired files, perform a mixdown.  The markers will be retained in the complete mixdown.  Open the Markers panel, select all the markers, then select File > Export > Audio within Range Markers...  You'll be able to export as MP3 files and each file will represent each marker range.
    If you're using Audition CS6, you can simply convert these Range Markers from CUE to CD TRACK and insert them into a CD Layout.  Be sure to set the track pause to 0 seconds so you get the smooth transition from one track to the next with no gap.
    May 16, 2012 8:23 AM   in reply to lost_keys
    If you are getting clicks you need to make sure that the Range markers are exactly on CD frames. So you need to have CD Frames selected as the Time scale and Snap to Frames turned on. But I thought that as soon as you converted Markers to CD Track markers that they automagically lined up with CD frames?
    May 16, 2012 9:34 AM   in reply to ryclark
    They should.  That doesn't necessarily mean that the CD Frame will align on a zero-crossing position, though, and if the CD player introduces any delay of its own when skipping between tracks, it would probably results in an audible click.
    May 17, 2012 3:08 PM   in reply to lost_keys
    At the moment you have Hours, Minutes, Seconds and Milliseconds selected as your time measurement on the Time bar at the top of the Waveform view. If you right click on the bar you will get a drop down menu allowing you to select different time scales. For CD production you need to select Compact Disc 75fps. Each second of CD audio is divided into 75 frames. In order to stop clicks between tracks you need to make sure that your tracks start and end exactly on a CD frame. To do this in the drop down Time menu you need to turn on Snap to Frame to make sure that your cursor snaps to a frame when you position it to edit your audio.
