johnnyfriday
Transcoding from 1080p 29.97 to 1080 50i?
May 13, 2012 2:32 PM
Tags: #to #transcode #converting #50i
Screen Shot 2012-05-13 at 3.26.59 PM.pngMy master project is mixed timeline of RED R3d's, Panni AVCHD and h264 and well as P2 material. I'm making my master as a TIFF, then need to send to Europe a 1080i 50i timeline to them with audio seperated....Can i get some of the tech savy to assist on this? :
Here's what i've done:
1. My sequence is set to: 1920x1080 @ 29.97  (see attached) with max bit depth & max render selected
2. Export media, then set my MASTER as a TIFF sequence at 1080p 29.97 with max set in Export settings dialague box as well--in both places
3. Send to QUEUE using AME for my Encode
4. Once finished (24 hours later)....then import TIFF file to a new Sequence--i am just choosing a Generic Sequence--like DSLR or anything that is 1080p @ 29.97...then i Render the sequence...SO--now i have my MASTER....
How can i get to a 1080i 50i Prouct for my client in the UK?  Stumped here since i see plenty of 1080i 25 and 1080i 60.....
    May 13, 2012 2:49 PM   in reply to johnnyfriday
    Why don't you make your life a lot easier and simpler, since you are using stills (.TIFF) by using a 1080/25i sequence without the Maximum Bit Depth? Or are you using 10 bit TIFF's and a third party card?
    May 13, 2012 7:01 PM   in reply to johnnyfriday
    Maybe I misunderstand things, but...why are you exporting three times?  TIFFs (or any image format) don't have a 'frame rate".  (And can't be interlaced anyway.)  Just export out once form your sequence as TIFFs.  The folks on the other end can assign whatever frame rate that want for playback in their software.  (Of course, they'll have to adjust the speed of audio playback to keep sync, but this is how Hollywood get's their 24 fps original onto PAL set's anyway, by speeding it up by 4%.)
    May 13, 2012 9:36 PM   in reply to johnnyfriday
    These are the Tech Specs I am to meet:
    1. Tapes
    OK, now I'm confused.  Do you need to send a tape, or TIFF files?
    May 14, 2012 9:23 AM   in reply to johnnyfriday
    If it were me, the first thing I'd do is ask the transfer house what format they prefer you to deliver to them.  Then just create that one output.
    Let them do the PAL conversion.  They're likely to have tools that do a better job than you can with the Adobe suite.  (And if they don't it may be time to look for another transfer facility.)
    May 14, 2012 4:01 PM   in reply to johnnyfriday
    Just change the export settings to 1080i/25.  (But you may not like the results.)
    May 14, 2012 10:10 PM   in reply to johnnyfriday
    1080i 50, and i deliver 1080i 25
    They're the same thing.  Some companies (who should know better) incorrectly label 1080i/25 as 1080i/50.  But they both mean 25 interlaced frames at 1920 x 1080 resolution.
    The results likely won't be viewable on an NTSC set.
    May 15, 2012 9:09 AM   in reply to johnnyfriday
    what you meant by me not liking the outcome was for that reason NTSC my side and not seeing it how a PAL system would show me....?
    No, what I meant is that Adobe tools may not do the best job of converting from 30p to 25i.  That's why I suggested you leave that to the transfer facility.  They often have much better tools for that purpose.
