Generate text from the effect controls
May 15, 2012 12:32 AM
Is it possible to generate text from a textfield (or something similar) from the effect controls?
I have an Adjustment Layer with a custom effect on it with a Slider, two Color pickers and four Checkboxes.
Can I somehow add a textfield that the user can input text in, and then link this to a text layer in the composition?
The reason I want this, is because the user can add all the information in one effect, instead of having multiple text layers to edit.
I don't think there is a textbox for this, but is there anpther way? Let's say I add an effect that has a dynamic name, that I can link up to the source text of my textlayers in the composition.
Any help would be much appreciated
Eirik
    May 14, 2012 6:49 AM   in reply to eiriksvensen
    No, there are no input fields, list controls, pop-ups etc. as expression controls. We've been asking for this for years, but apparently Adobe thinks that other stuff is more important... Anyway, it's perfectly possible to create code to dynamically address items based on text or otehr criteria, but unless you are more specific, I'm afraid we can't really help you. Post the code and explain what you want to do.
    Mylenium
    May 14, 2012 7:18 AM   in reply to eiriksvensen
    Any property can be addressed with the .name method and returns a string and effects can be renamed, can they not?! ... If that doesn't give you any ideas or it isn't good enough, then editing some text layer/source text property natively is your only other option, though that doesn't mean it wil lhave to be the layer you use for animation...
    Mylenium
