I have the following error since CS6 when exporting some videos: Export Error. Error compiling movie. Disk Full.
All my drives have plenty of space, NTFS 7200rpm, everything was fine with CS5.5. Same problem with Encoder or Premiere Pro.
Much of the stuff I export is going fine but I have this error with some sequences and formats.
It always crash to this error when exporting sequences with "Match Sequence Settings".
For one of my projects, when exporting to wmv, out of 6 sequences one always crash to Export Error. Error compiling movie. Disk Full.
If I encode those sequences to mpeg2, everything is fine.
I installed the new update this morning but it doesn't help.
You mentioned MPEG2 does not have this issue and WMV does have this issue. What other export formats have you tried that have or not have this problem. Just for sake of narrowing down this issue, would you remove all effects you have applied to projects/sequences and try to export that project and see it the problem goes away? Another test for WMV is to select a different Bitrate setting in Export Settings [Video tab]. Default is VBR, try selecting CBR and see if that solves the issue.
What I said about wmp is that 1 on 6, with the same settings, it don't works. I did some testing this morning with a new 1 minute - no effects timeline from Canon XF 720p60. I tested wmp, mpeg2, "match sequence settings" and mp4. It alway crash at about 14%. That very bad because I have to export my video everyday for my job...
I tried with my old project with AVCHD and I'm still able to export to mpeg2 and 5 times on 6 in wmp. Changing the bitrate doesn't help.
The part about AME incorrectly reporting that the disk was full sounds similar to a bug that we found late in the cycle and thought that we had fixed.
Are you encoding multiple outputs in parallel? If so, please try with the Enable Parallel Encoding option disabled in the Preferences dialog.
Is AME crashing or hanging, or is encoding failing but the app continues running and remains responsive?
I have new infos. It seems that the percentage doesn't matter. In fact, it always crash at 30 seconds of the sequence. If the sequence is shorter then 30 seconds, it will not crash. If the sequence is 31 second long, it will crash at 99%. Also, all projects created originally in PP CS6 will always crash. So there is no way to export a project originally created in PP CS6. However, the projects originally created in CS5.5 and converted to 6.0 will not crash if exported in mpeg (for the moment) but will always crash with "match sequence settings" and will randomly crash with other settings / format.
I really need a solution for yesterday to export my projects. Adobe provide pro applications for pro at fairly high price, there's plenty of bugs in CS6 and it's unacceptable. I can't tell my client to wait after Adobe.
I7 2600k on P8Z68V Pro
C: on crucial m4
D: and E: on WD 2T 7200 RPM
16GB ram
thank you for your help
I have the same error popping up. My hard drives are formatted NTFS and have plenty of space. I'm working on APE 4.0. I tried encoding into an internal and external hard drive.
I'm trying to encode a 4:00 Film into .mpeg format. But the error 'Error compiling movie. Disk Full.' keeps popping up. If I encode into AVI it goes through.
I don't get this error... I want to encode into mpeg.
I sympathize with my friend and I would really like to resolve this issue. Thank you!
I have this problem all the time. Its something Adobe needs to fix but there are two ways to get around it.
1.Delete all your render files in the project and try again.
2.Turn off the mecury playback engine use software only.
I have found the mecury playback engine to be unreliable and I am dissapointed with its use in a real production enviornment. It's just a cool toy Adobe uses to sell there product.
Also your effects will change when switching to software render so retweeking the whole project will be nessecery.
Sorry to come late to this party but i am experiencing a very similar issue, well at least i think i am.
I am using CS6 (creative cloud) on a mac and when using AME, I am getting constant disk full messages. this does not happen when exporting direct from prem pro (even when exporting to higher bit rate formats).
My media cache settings are correctly set to my scratch disk and not my system drive and so i just can't see what might might be causing this problem.
Any help would be gratefully received.
Cheers
Ben
Most of my problems come from importing old projects. They are very strange and random and if I try and duplicate them I can't. Turn off the mercury playback engine (If your system is using it) use software only see if that helps.
Project / project settings / Render: mercury playback engine software only
I find this causes %90 of the stability issues in premiere.
Check out this strange bug. This was an imported CS5.5 project the bug only happens when using secondary color correction with a blurred mask and pop in a non real-time effect. And only while using the mercury playback engine GPU acceleration. But if you clear the effects and recreate them the bug is gone. ( Strange right?)
yeah that is strange. i am using the mecury playback engine and the video i have been struggling to output had a magic bullet looks effect on it. (and like i say was imported from 5.5).
My system disk is an SSD which is quite small so i thought that might be the issue but i definitely haven't had this problem before and as I said in my first post, i can output a higher quality file from prem pro with no problem at all.
Ok everyone I have been on the phone with Adobe about similar issues. They have rewritten the timeline code in CS6 and admit there are bugs when importing from older versions of premiere. I suggest you continue using the older versions of premiere with projects not created in CS6. They are working to fix the problems. But please call adobe and report the problems to their technical support team. If the problems are not reported they can’t fix them.
I'm also having a similar problem. I have a 2 hour 20 minute XDCAM EX project, orignated in CS6, which I'm trying to export as MXF. I've tried deleting the render files and rendering without the GPU acceleration and AME still fails a few moments into the encode, with an 'unknown error' file. I've also tried splitting the project and exporting in two halves - still no luck. All of my work is XDCAM and I nearly always want to export my projects as MXF. So how am I supposed to complete anything when I can't export it? Please tell me that Adobe is going to sort this out very soon, as at the moment Premiere Pro is seeming like a waste of money.
eajg: I recommend that you start a new thread about the issue you're encountering, and include as much of the info requested here as possible. Also, please file a bug report and attach your project to it--without any content at least to start with. You'll find that AME is not listed among the products, so set it against Premiere Pro.
You're on the right track in troubleshooting this by breaking the sequence down. In addition to cutting it in two by duration, I'd suggest simplifying both in terms of layers and effects, too.
I have exactly the same problem. The project was not created using an earlier version, I have deleted all the render files and am using the MPE software only. No joy.
When trying to export using "match sequence settings" I get the disk full error. My disk is not full.
I have never enabled parallel encoding and don't know where to find it in preferences. Using any other encoding options it works fine.
Now, I have both Premiere Pro CS6 and CS5 installed on my computer. I created the project in CS6 (and this is where I get the error). However, if I open the same project in CS5, (after the dialogue to convert the CS6 project to CS5), I can export it using "match sequence settings" in CS5 fine, no problem. No change, exactly the same souce, sequence and action, just a different result. In CS5 it works, in CS6 it gives this weird error.
Hi, since my last post there has been no activity on this thread, so...
Has anyone found a workaround? I find it incredibly inconvenient and unforgivable that I get this error when trying to export a movie in PPCS6 using "Match Sequence Settings". Some facts:
1. I always get this error when trying to export from PPCS6 using match sequence settings. It happens with all movies. Starting a new sequence doesn't change it
2. I never get this error if I use another encoding option
3. My disk is not full
4. It happens whether I use software engine or GPU acceleration (and also if I delete the previews)
5. It happens on both the PC and MAC versions of PPCS6. With sequences created natively on each machine and imported one to the other.
6. If I import the sequence into CS5, then hey presto, it works without error. At the moment that is my workaround, but it is not at all acceptable that I have to do this.
7. The sequences were all created in CS6. None of them were imported from another version
8. My source video is 1080p AVCHD footage
Any further thoughts on how to deal with this really frustrating and crippling new bug in CS6 would be incredibly welcome.
I just encountered same error when trying to export a shakey clip for offline processing in Mercalli SAL (Warp Stablizer does not work when No Motion is selected). AVCHD 1080p 60fps. 23 second clip. Error exporting clip. Disk full. Bogus msg; plenty of room on the disk. New install of CS6 Creative Cloud. No coming up from prior versions. And for all the talk about Direct Export as an option, I don't see it in the Export menu. Only choice is to go thru the AME.
I have just started getting this problem too!
It is strange because it has just begun after my latest patch upgrade.
Whenever trying to export from PPCS6 using match sequence settings it always says disc full even though there is 700GB available!
The encoder works with mp4, wmv etc ok, but as soon as I choose 'match sequence settings' it says disc full.
A few weeks ago all was fine, but now it fails all the time ... It is very infuriating as I use this setting OFTEN (well, that is until recently!)
I consistently got this error when trying to export AVCHD 1080p60 footage. For lower frame rates, simply checking the "Match Sequence Settings" option worked well. Not so for the 59.975 frame rate.
After fidddling with it for a while, I finally got it to export by unchecking the "Match Sequence Settings" option and manually selecting H.264 Level 5.1.
