Video Format for Muse?
May 14, 2012 8:51 AM
Tags: #muse #video_format
Does Muse support video formats AIFF or MPEG-4?
    May 14, 2012 9:08 AM   in reply to dave3110
    Muse does not support video.
    The current workaround (to place video in a web page) is to use the "insert HTML..." function from Muse's "Object" menu.  You can paste in the HTML needed to display video. This HTML can be found on video hosting sites like YouTube.
    May 14, 2012 9:32 AM   in reply to Marian Driscoll
    Thanks Marion. What is the best way to generate an HTML code from a video, not from youtube. Can I get the video published on the internet somehow and get the code that way?
    May 14, 2012 9:49 AM   in reply to StudioPentimento
    How comfortable are you with HTML? If not much, these third party video hosting sites (YouTube/Vimeo/etc) are your best option.
    If you are comfortable with HTML and want to host video on your own server, take a look at FlowPlayer. You can embed FlowPlayer's code with Muse's insert HTML function. You'll also need to copy the FlowPlayer files to your server and convert your video to a web-friendly format. Details appear on the site:
    http://flowplayer.org/
    May 14, 2012 12:22 PM   in reply to dave3110
    Hi Dave,
    Muse supports both the embedding of .swf videos on the Muse site directly, or streaming of video content from video hosting companies like AdobeTV, Vimeo and YouTube. You can use the embed/sharing code provided by these services to include video in your pages.
    For step-by-step instructions on embedding a video please check out the tutorial here: Adding a lightbox feature that displays video hosted on a third-party server
    Best regards,
    Corey
    May 14, 2012 1:24 PM   in reply to Corey@Adobe
    Corey@Adobe wrote:
    ...Muse supports both the embedding of .swf videos on the Muse site directly...
    Here are the steps to make a SWF video:
    http://www.adobe.com/designcenter-archive/tutorials/videoencoderwizard /
    You'll need to buy Flash, if you don't already have a license.
    May 15, 2012 10:32 AM   in reply to dave3110
    Hi Dave
    Try out videomonkey
    its free simpel and it works in a split
    and convert it all
    http://videomonkey.org/
    Best regards,
    Helen
    May 16, 2012 5:29 PM   in reply to dave3110
    I am using ConverterLite at to convert the file formats.  http://www.converterlite.com/ . I found that if I make a rectangle, select "Place", select the swf file, the curser loads with the image and in preview the video plays. Problem solved!
    May 19, 2012 10:54 PM   in reply to Corey@Adobe
    Hi Corey,
    I follow the indtructions but could not get the youtube video to load in the light. I use other sliders but get the same result of seeing the video on the page.
    So, it seems like the video only loads to the main page, not at the sepecific location of the light box.
    With the container selected, I try both methods paste youtube embeded code directly into the selected areas of the container, and use objectwith insert HTML. The video didn't load into the widget BUT to the page.
    are there any other methods? Or any other settings?
    Appreciate any assistance. Thank you.
    May 20, 2012 11:59 AM   in reply to vyctmuse
    I have been struggling with the video placement in Muse.
    I found that if you go to design viw of the page you want to ad video to, go to file place, select the video in the swf format. The video will load into your curser. Click the page to place the video abd resize it.
    I made a sample site, placed two video loops on two different pages and so far its working, but we'se!
    Aug 2, 2012 1:00 PM   in reply to dave3110
    I am told SWF does not work on moble devices, what other options are there so that my web pages will work in all OS
    Mar 11, 2013 1:11 PM   in reply to dave3110
    <object classid="clsid:02BF25D5-8C17-4B23-BC80-D3488ABDDC6B" codebase="http://www.apple.com/qtactivex/qtplugin.cab" width="320" height="256" >
    <param name="src" value="your video here">
    <param name="autoplay" value="false">
    <param name="controller" value="true">
    <embed src="example.m4v" type="video/mp4" width="320" height="256" controller="true" controls="true" autostart="false"/>
    </object>
    put the url of your video where the your video here leave the " "
    change the width="320" height="256" to what ever dimensions your video is.
