TomBerglie
Urgent: File > Folio Preview opens an empty "Folio Preview" panel (ID CS 5.5)
May 9, 2012 11:45 AM
Hi!
I just updated The Folio Builder panel, and the command File > Folio Preview does not send the document to the Content Viewer as usual, but opens a new panel called Folio Preview ..., which remains empty.
I can preview documents as usual using the Preview button at the bottom of the Overlay Creator panel, but not using the menu command. There is a check mark next to the Folio Preview command on the File menu when the panel remains open. (Doing some searches on this forum, there seemed to be a similar problem last October, but I would have thought it should be solved by now.)
I'm experiencing this problem on both my PC running Windows 7 and my MacBook Pro running Mac OS. (Both laptops are running the Norwegian version of the repective OS.)
I can work around the problem using the Overlay Creator panel, but if anybody has an explanation and/or solution I would be very grateful. I'm starting a two day course teaching DPS tomorrow, so this is rather urgent.
Best regards,
Tom
PS. I'll try to upload a screen shot shortly to clarify the situation.
    May 9, 2012 8:31 PM   in reply to TomBerglie
    I'm experiencing exactly the same issue as Tom describes. Seems to be new behavior since the latest update.
    May 14, 2012 9:05 AM   in reply to KeithGilbert
    Neil Enns confirmed this in another thread. You can evoke the Preview in
    the Overlay Creator, there it should work.
    —Johannes
    May 14, 2012 11:24 AM   in reply to Johannes Eckert
    Yes, this is a known issue in CS5 and 5.5. You can invoke folio preview from the Folio Builder panel instead and it will work fine. See http://forums.adobe.com/message/4399358#4399358 for my message about it.
    Neil
    May 15, 2012 12:36 AM   in reply to TomBerglie
    Sorry Tom for not reading all the content of your post ,-)
