cigowie
embeded swf file
May 14, 2012 1:11 PM
i am using as2 and i want to embed a swf file into another swf project and have the embeded file play once the site is loaded can someone help please.
  • kglad
    Jul 21, 2002
    May 14, 2012 1:13 PM   in reply to cigowie
    you can load a swf file into another swf using loadMovie(), loadMovieNum() or loadMovieClip().  is that what you want to do?
    May 14, 2012 4:37 PM   in reply to cigowie
    Just put the code that is inside the function in a frame of the timeline where the movie is...
         this.loadMovie("mymovie.swf",moviswf);
    the rest of the code is what makes you need to click
  • kglad
    Jul 21, 2002
    May 15, 2012 7:12 AM   in reply to cigowie
    do you want to load "mymovie.swf" when your main swf starts or when a button is clicked in your main swf?
    if the former, assign your button an instance name (eg, btn) and attached to a frame (NOT the button or any other object), use:
    btn.onRelease=function(){
    moviswf.loadMovie("mymovie.swf"); // assuming moviswf is a movieclip that you want to replace with mymovie.swf.  p.s.  watch your spelling of moviswf.  it's probable that should be movieswf
    if the later, just use:
    May 15, 2012 7:50 AM   in reply to cigowie
    That error is because you are attaching the code to the object, not the timeline.  Click on a frame and enter the code.
  • kglad
    Jul 21, 2002
    May 15, 2012 9:15 AM   in reply to cigowie
    click an empty part of the stage (to deselect everything), click your button (to select it) and in the properties panel you'll see a input field where you can type an instance name.
    if you don't see a properties panel, click windows > properties.
