Button widget - add javascript?
May 14, 2012 10:19 PM
I would like to add a Close button to my master slide that executes javascript: window.close().
Is there a way to do that with the button widget?
    May 14, 2012 10:32 PM   in reply to SavvyEd
    That option is not listed in the dropdown for this widget.
    Interactive objects cannot currently be added to Captivate master slides.  So you cannot do this with a normal button or click box either.
    There is a Close button that can be added to the playback bar, but whether or not it will close your window depends on a number of factors.
    May 14, 2012 11:30 PM   in reply to SavvyEd
    As Rod told, the button widget is a static widget with limited functionalities, but I like it nevertheless because you can use it on master slides/question slides. Just an idea, didn't try it out:
    1. use the button widget to jump to a short slide (at the end of the course), which is possible
    2. add the JS to the On Enter action of that slide
    Lilybiri
