I have a couple of Illustrator questions that are driving me crazy. I'm sure there is a very simple answeer for these.
1. When I draw a stroked path and then apply a textured charcoal brush effect to it, how do I colour it? It keeps giving me tint/shades or black options - not the specific full hue of what I'm trying to apply. Even when I tell it to use "None" in the colourization method...
This is driving me crazy! But simple I'm sure of it.
2. How do I adjust the tapering of a "tapered" brush stroke?
3. How do I adjust the amount of texturing to the charcoal brushes?
Thanks a million!
Cheers,
J
Hi James
Are you trying to use the default charcoal brushes? If so, they should colorize to whatever stroke color you choose without a problem. Perhaps you mean that the color panel is only showing the grayscale/black ramp? If that's the case, open the stroke panel flyout menu and change the color space to RGB or CMYK and you'll get color options. Alternatively you could double click the stroke icon in the color panel or the tool panel and choose a color from the picker that pops up. If that's not what you mean, please clarify.
As for adjusting the texturing and tapering of a brush, you'll really need to edit the shape that made the brush and then resave it as a new brush. Simply drag the brush shape from the brushes panel onto the artboard. it will appear as paths that you can modify. Use whatever means you want to change the texture, filters or manually. Then I'd suggest either the transform tool or the scale tool (set to non-uniform) to adjust the taper. When it looks the way you want it to, drag it back on the brush panel. Charcoal brushes are art brushes so choose that when the popup asks. Colorization method should be set to "tints". That should do it.
if you want to re-use that brush, be sure to save it. Go back to the flyout menu in the brush panel and choose "save brush library"
Michael
http://www.learnadobesoftware.com
edited: added the line 'Colorization method should be set to "tints".'
Message was edited by: Michael Riordan
Hi James
Really there is no difference between the 2 brushes. The panel labelled "Artistic_ChalkCharcoalPencil" is simply one of the collections of brushes that come with Illustrator but are not necessarily preloaded. There are many more, accessible through the little icon at the lower left corner of the brushes panel. Notice that if you click on the brush just under the one highlighted on the left, it will be loaded into the brushes panel on the right, making it accessible and usable. So it;s the same brush. you can close the left panel if you don't want to load any of the other brush options.
You're welcome! Sorry I couldn't get to the heart of your problem.
719 S Grove Avenue
Oak Park, Illinois 60304
michael@learnadobesoftware.com
708-655-8507
Look at that. Learned something new today. Nice Monika.
Would be difficult to solve it at all, becausse brushes functionality, color mode and color management play in this together.
In order for the brushes coloring to work, you need them in either K100 (but grayscale black works as well) or RGB000 depending on the color mode. So what you would need are two sets of brushes libraries. But then people might be troubled even more deciding which one to use.
You don't need two sets of brushes libraries. You need one set of brushes created in RGB color mode of the document not RGB color mode of the color panel which in CMYK color mode of the document is still CMYK colors converted to RGB numbers. The color mode of the document is displayed in the title of the document's window and can be changed from File > Document Color mode. Brushes created in RGB color mode will always give equal color in any of the CMYK color spaces because CMYK gamut has lighter blacks.
Adobe made a stupid mistake by creating brushes in a CMYK color space. When the blacks of the CMYK color spaces are converted to RGB color spaces they are not fully black because the color management matches the colors - the full black in a CMYK color space matches some dark gray in a RGB color space because RGB color spaces have wider gamut allowing darker blacks not possible with CMYK spaces.
This is not a bug, simply bad workflow used by the people who created the brush libraries and users have to fix that by recreating the brushes in RGB color mode of the document.
Actually there already are two sets of brushes.
If you open a new document in RGB, you get RGB brushes, RGB styles, RGB symbols, RGB Swatches, etc.
If you open a new document in CMYK, you get CMYK brushes, CMYK styles, CMYK symbols, CMYK Swatches, etc.
The issue presents itself when a document starts in one color mode then the user switches to another.
@Scott-Sorry Scott but I beg to differ. I tested the problem again, starting with a new document set to RGB. The color did appear as R=0, G=0, B=0 in the color panel when the brush was initially applied, but the problem with the color still occurred when a new color swatch was chosen. It doesn't seem to matter if you start with RGB or CMYK.
Hi guys, thanks for all of the input into answering my questions about brush colour.
Just to be clear, I'm only working in RGB , not in any way CMYK.
Can I please ask for a final summary on this so it's clear to me and anyone else finding the same issue for future reference.
Thanks again. Greatly appreciated!
So I've been playing with the brush colour again.
It's still happening.
Every time I make a new brush and apply it to a stroke, I can't change it to a different colour?? It stays the same as the original colour.
This is driving me CRAZY!
Something so simple. Do you guys know what I'm talking about?
