hi,
i downloaded Photoshop cs6 trial and when i click the Photoshop icon to open the software i get a window:
Photoshop.exe - Entry Point Not found
The procedure entry point GetLogicalProcessorInformation could not be located in the dynamic link library KERENEL.32.dll.
What can I do???
I have allready tried to reinstall....
still the same.....
HELP
Please run the Adobe Support Advisor - http://www.adobe.com/support/loganalyzer/ to verify there was no installation error. Do you have a previous version of Photoshop installed? If so is it functioning properly?
I'm having the same issue. I'm running Windows 7 pro 64 bit and I've got Photoshop CS5 extended and that runs fine. I've downloaded the support advisor and it didn't find any issues either. What else is there to try? I can find the file everything was downloaded to and I click on the setup and I get the status bar looking like it is doing something but when it gets to the end it doesn't do anything.
Cmoss5 before I move this thread over are you sure you have the same issue as the original poster? OK32ISR stated the following, "
The procedure entry point GetLogicalProcessorInformation could not be located in the dynamic link library KERENEL.32.dll."
This to me seemed to indicate the error was received while opening Photoshop not installing. Is this the exact error message which you receive?
