Why can I not move files in LR from 1 HDD to another
May 15, 2012 11:47 AM
Hi there.
LR 4
I need to move a bunch of pictures located in different sub-folders on Drive C: to my new 2Tb Drive D:
I try to move it in LR via the import function with MOVE. But, they are all greyed out (not selectable) and when I try to move 1-by-1 by right-clicking on a picture, a message is displayed telling me that the picture is already in the catalogue. I know it is already in the catalogue. All I need to do is to move it to another HDD.
How would you do this? I have just thought of deleting all files in the catalogue and import them then, but it just does not feel right.
Your suggestions will be very valueble.
    May 15, 2012 12:08 PM   in reply to DeonH
    Are the files already in Lightroom?
    If so, that's why they are greyed out.
    Do not use import.
    • Review your backups – if something did go wrong, would you be able to restore and get everything back to where you are now? If the answer’s not an emphatic “Yes”, you should sort this out before going any further.
    • In your Lightroom catalogue, in Folders, click the + and add a new folder on the new drive
    • Still in Lightroom, now drag folders from your existing hard drive and drop them on the new drive.
    May 16, 2012 9:52 AM   in reply to DeonH
    Do you see your new @TB drive D in LR? If yes, create a new folder there as John said. In Grid View on the left side is the folders panel. You create the new folder in the folders panel. Right-click where it says "D:" and select <Create folder inside D:>.
    Then still in the folders panel drag-and-drop the folders from your old drive C to the new folder you just created on drive D.
    But as John advised make a backup of your catalog first. Go >Edit>Catalog Settings and at the bottom of the General tab select <Every time Lr exits>. Then close Lr and the backup dialog will appear. Choose a location for your backup - maybe your new external drive and create the backup. Lr will close down after that. Re-open Lr and do the move of the folders as described above.
    PS: Do NOT use the import function. You said "is it on the right side?" No! that's in the Import dialog. Cancel import and go to Grid View. the folders panel is on the left side there.
    Message was edited by: web-weaver
    May 16, 2012 11:27 AM   in reply to DeonH
    Yes, date order, and put time into keywording.
    Leave the existing folders as they are, and just get new photos into a data-based system.
