Noise reduction not working correctly?
May 14, 2012 10:00 PM
Hey all,
First time posting in the Audition forum. I am using the trial of CS6 for mac.
I am not a master of audio by any means, so please excuse me if this is an easy answer.
I am in Premiere editing together a movie trailer. Some audio clips with dialogue have background noise I need removed, so I used the dynamic link to bring it over to Audition (a really cool feature).
Once in a go through the steps necessary to remove some of the background noise:
I select a length of the track in which we can only hear the background noise. Then I go to Effects>Noise Reduction>Capture Noise Print.. alls good.
Then I go and select the entire audio clip, then go Effects>Noise Reduction>Noise Reduction (Process)
Hit Apply, and go back to my audio clip, but only a small section (i.e only a portion of what I had selected) actually underwent the noise reduction. The first part sounds fine, but then the noise comes back in.
Also, when I use the adaptive Noise Reduction, it seems to work when previewing in the effects window, but when I apply, it only applies itself to a certain part of the clip, despite the fact that the entire clip was selected. I also noticed that the audio seems to "slide" between the part with noise and the part with no noise.
I would think I was doing something wrong, but when I try the exact same steps using Audition CS5.5, everything works perfectly. I just can't use the dynamic link which is a huge pain. It's just weirding me out that it's not working correctly in CS6.
Has anyone experienced this, or maybe have any solutions?
Best,
Dan
  • SteveG(AudioMasters)
    Oct 26, 2006
    May 15, 2012 2:35 AM   in reply to dh91
    Well, not having the Mac version, and also not using Audition for video, I can't replicate your situation at all, but I'm assuming that once you've got your file into Audition, everything will be the same. So, I have a question:
    When you select the entire clip, does the display maximise to show the whole file, and the whole thing turn white?
    The only safe way (in this non-modal situation) of selecting the entire file is to go Edit>Select>All (Ctrl-A), and not rely on mouse movements...
    May 15, 2012 3:36 AM   in reply to SteveG(AudioMasters)
    When you open the Noise Reduction page do you click on the Select Entire File button?
    May 15, 2012 3:56 AM   in reply to dh91
    I just tried some noise reduction (using the Select Entire File Button in the NR control screen) and all worked fine.
    The only potential difference is that I don't have Premiere so I was working on one of my "purely audio" files.
