sdkurland
How to debug jrun crash 0xc0000005
May 15, 2012 1:35 PM
Tags: #crash #cf9 #jrun
I am running Coldfusion Server 9.01 Professional 32 bit version on a Windows 2008R2 server.
A few times a day the Coldfusion Server will crash upon trying to access a webpage.  There is no particular page that seems to cause the crash, although I am using the CFWheels framework.
The event log shows:
Application Error
Faulting application name: jrun.exe, version: 4.0.7.43259, time stamp: 0x4a98c922
Faulting module name: ntdll.dll, version: 6.1.7601.17725, time stamp: 0x4ec49b8f
Exception code: 0xc0000005
Fault offset: 0x00038dc9
Faulting process id: 0x158c
Faulting application start time: 0x01cd32cf63092070
Faulting application path: C:\ColdFusion9\runtime\bin\jrun.exe
Faulting module path: C:\Windows\SysWOW64\ntdll.dll
Report Id: 24cc34e0-9ec8-11e1-8872-069b289e9fe7
Windows Error
Fault bucket , type 0
Event Name: APPCRASH
Response: Not available
Cab Id: 0
Problem signature:
P1: jrun.exe
P2: 4.0.7.43259
P3: 4a98c922
P4: ntdll.dll
P5: 6.1.7601.17725
P6: 4ec49b8f
P7: c0000005
P8: 00038dc9
P9:
P10:
These files may be available here:
C:\ProgramData\Microsoft\Windows\WER\ReportQueue\AppCrash_jrun.exe_a62 ee8217a354cdaa17f149f517bab8292a17f_20739c5f
Analysis symbol:
Rechecking for solution: 0
Report Status: 4
Where do I start looking for a reason for this crash?  Is there a particular log file or debugging tool that would be helpful?
Thank you,
--Scott
    May 15, 2012 3:52 PM   in reply to sdkurland
    Check ColdFusion9\runtime\logs\ coldfusion-event.log and coldfusion-out.log for errors warnings. That would be Jrun4\logs in case of multi-server install.
    That is a little odd CF9 32 bit on Win 08 r2 which is 64 bit. Perhaps you have configured JVM parameters with too much maximum memory when CF9 / Java 32 bit can only address about 1.4Gb total?
    Lastly Scott any reason not to run CF9 64 bit?
    HTH, Carl.
