Known Issues in new skins
Jul 17, 2012 3:02 PM
  Latest reply: RickCP, Aug 28, 2012 9:54 AM
Replies 1 2 3 4 5 6 7 Previous Next
    May 12, 2012 7:30 PM   in reply to Pat Willener
    Pat Willener wrote:
    Dave Merchant wrote:
    If you personalise your homepage, you can include the tree-view widget that shows every forum (along with anything else you want).
    http://forums.adobe.com/index.jspa?showpersonalized=true
    Thanks; didn't know about that!
    But shouldn't Adobe/Jive be reponsible for providing this very basic functionality, easily available in non-Adobe forums?
  • PECourtejoie
    Jan 11, 2006
    May 14, 2012 5:41 AM   in reply to adobe-admin
    The product icons are still the ones from CS5, and the Photoshop one seems to be saved without transparency, compared to the Illustrator one.
    May 15, 2012 8:12 AM   in reply to Jacob Bugge
    When I hover the mouse over the Report link it just shows the hand, nothing else.
    Jacob,
    It is the same for me too. At least the "hand" has the index finger raised, and not another one...
    Hunt
    May 15, 2012 8:13 AM   in reply to Noel Carboni
    Noel,
    Thank you for that tid-bit.
    As I am usually reading a thread/reply up a bit on my screen, I had not noticed that info.
    Appreciated,
    Hunt
    May 15, 2012 9:02 AM   in reply to Claudio González
    Claudio González wrote:
    Incidentally, when I clicked on the Reply button of the opening message of this thread to post this message, I was not taken to the last message but here:
    I had reported the same problem before these great changes, but nobody seemed to care or take notice.
    Nobody seems to take notice or care about he probnlem I re-reported in the above message, which is not in the list on known issues.
    May 15, 2012 11:13 AM   in reply to adobe-admin
    Just to rereport, in the hope that these issues will be added to the list:
    Here is an even more striking appearance of what I reported in post #49 and demonstrated in post #54, notice the image at the bottom of the OP:
    http://forums.adobe.com/thread/1005265?tstart=0
    Also, the hovering over the Report button reported in post #102 still only shows the hand.
    Both persisting after cache clearing.
    FF12.
  • Noel Carboni
    Dec 23, 2006
    May 15, 2012 11:31 AM   in reply to Jacob Bugge
    Have you tweaked up the forum presentation via local changes so much that you can now see post numbers again?  Hard to imagine anyone is counting posts by hand, and I wouldn't know whether to start with 0 or 1.
    I don't see anything obvious wrong with the image in the thread you identified, because you haven't provided quite enough context.
    -Noel
    May 15, 2012 12:27 PM   in reply to Noel Carboni
    Noel,
    If you switch to page 2 in this thread, my post #54 is fifth from the top, and it shows a screenshot of the appearance with the OP text in a narrow column to the right, and on top of that the box to prove that it still happened after clearing the cache. This post was an answer to post #50 by Dave at the very top of page 2, which in turn was an answer to my post #49 at the very bottom of page 1.
    That is the issue that I, and some others, see in certain threads:
    It seems that some silly tags eat up most of the space, working like Tabs, so the OP text only has a very limited width.
  • Noel Carboni
    Dec 23, 2006
    May 15, 2012 1:36 PM   in reply to Jacob Bugge
    Interesting, because no matter how wide or narrow I make an IE, Firefox, or Safari window on the thread you identified, I can't make that "text squished to the right" problem occur.  I tried different zooms as well.
    I can't help but think that somehow you haven't gotten all the latest bits and pieces due to caching or...  ???
    -Noel
    May 15, 2012 2:39 PM   in reply to adobe-admin
    Noel, John,
    A moderator might have already fixed it.
    Well, it seems to be partly fixed. This thread looks right now,
    but this one is still funny.
    http://forums.adobe.com/thread/999642?tstart=0
    As noted before, the fix for this squishing on messages has been identified and is scheduled to be in the next forum update.
    Thank you, John. I look forward to that; I have some recollection of your mentioning it before, in another thread, I believe.
    May 16, 2012 7:41 PM   in reply to adobe-admin
    The "action bar" at the bottom of posts:
    appears bit-by-bit, not all at once.  More than once I tried to click on one action button (e.g. Edit), when during the click it was replaced by another button (e.g. Delete).  Even on my rather fast Window 7 system, the whole building of that bar is very slow.
    Is that some very slow JavaScript building it?  Isn't there a way to send out that complete bar at once?
    May 17, 2012 3:27 AM   in reply to adobe-admin
    I see, John. Thank you for the clarification.
    May 17, 2012 7:55 AM   in reply to Pat Willener
    Mine comes on all at once, but when you hit Add Reply your answer appears, it blinks off then the message and action bar appears.  Takes 1 sec I would guess.  Win 7, Firefox browser.
    May 17, 2012 8:01 AM   in reply to adobe-admin
    adobe-admin wrote:
    Right. Each one needs to be fixed individually until the overall fix is rolled out in the next forum update.
    The new forum udate is taking longer than most of us had hoped for.  The "any day now" has morphed to weeks.
    Any chance it can be rolled back to previous version?
    Would like to see a REAL beta test on this Forum to get the bugs worked out before it goes public.
  • Noel Carboni
    Dec 23, 2006
    May 17, 2012 12:02 PM   in reply to Curt Y
    Could it be that no actual "improvements" are forthcoming?
    No disrespect intended to John C. and the other fine folks trying to make this work, but we have to start to consider this:
    Perhaps the forum is the way it is because someone in charge, possibly in a near-vacuum, has decided that all the stuff we're missing isn't good to have, and that a simpler interface is better.  This might be the same decision-making that led to the inclusion of social networking garbage (that thankfully can be blocked).
    I suppose it's just barely possible - though I'll believe it when I see it - that further web software releases are now being subjected to actual testing before release.
    -Noel
    May 17, 2012 3:57 PM   in reply to Noel Carboni
    Improvements are coming.  I'd like to see them happen a bit faster as well, but they do have some fixes and changes being tested.
    May 17, 2012 8:51 PM   in reply to Chris Cox
    Here is a screen shot of some of the fixes being tested right now. If all goes well, they'll be in place on May 24.
    I've been out of the office most of this week doing some volunteer work with cancer survivor portraits, so I've been quiet here. But there are a number of people actively working on this.
    John
    May 17, 2012 8:56 PM   in reply to John Cornicello
    And the advanced editor is back...
    And the missing/squished text in messages and documents with a lot of keywords should be fixed, too.
  • Noel Carboni
    Dec 23, 2006
    May 17, 2012 9:15 PM   in reply to John Cornicello
    Thanks for the hopeful words, John and Chris.
    Here's hoping the changes are tested on more than one computer.
    -Noel
    May 17, 2012 9:21 PM   in reply to Noel Carboni
    Not everything is on the fixed list yet, but I expect a few more revisions over the next few weeks.
    May 18, 2012 4:05 AM   in reply to John Cornicello
    Not here (FF/Mac):
  • PECourtejoie
    Jan 11, 2006
    May 18, 2012 6:17 AM   in reply to Claudio González
    Claudio, I guess that John speaks about the May 24 update.
    May 18, 2012 7:13 AM   in reply to Claudio González
    It isn't May 24, yet in Seattle.
    May 18, 2012 2:49 PM   in reply to PECourtejoie
    Yes, sorry, I missed the May 24 part.
  • Noel Carboni
    Dec 23, 2006
    May 18, 2012 5:07 PM   in reply to Claudio González
    While I may be living in the past, John clearly lives in the future.
    -Noel
    May 19, 2012 12:16 AM   in reply to John Cornicello
    As for the "action bar" I mentioned earlier; I have now observed it very carefully, and it is displayed in two parts
    so there is no real danger that I hit Delete by mistake.  But trying to hit Reply, Edit, or Delete may end up as something else (nothing, helpful:Yes, or helpful:No).  This is just plain irritating.
    Couldn't that bar be pushed out in one go?  Or at least put the left items first, then add subsequent items on the right?
    May 19, 2012 12:22 AM   in reply to Pat Willener
    Not sure if this has already been listed; the above images are completely immersed in the gray background, there is no way to see where the picture begins or ends.  I have manually added a black border to the images itself, which now look like
    May 21, 2012 4:52 AM   in reply to adobe-admin
    I don't see this in the initial list, and there are too many posts to check if this has already been reported. I am getting these ghosts images in some messages, not in all; and I have not noticed any pattern; i.e it looks like a random effect. This screenshot is from the Reader forum.
    May 21, 2012 5:30 AM   in reply to Claudio González
    Once we had the fair forums.
    Now we have the haunted forums.
    Apart from ghost images, I just saw the cursor jump to the far right side of this message box.
    I had to exorsize what appeared to be  a nothingness to get back to writing.
  • Noel Carboni
    Dec 23, 2006
    May 21, 2012 5:33 AM   in reply to Claudio González
    Those are the tags, Claudio.
    The other major problem with these, besides them being unreadable, is that when there are too many (and the window is too small) they push the text off to a tiny column on the right.
    The answer is:  If they're not useful enough to be made readable, just leave them off.  Does anyone actually use or look at tags?  I think maybe I've seen once whether a user, who neglected to mention it otherwise, had a Mac or PC, but otherwise they are singularly unhelpful.  Like an electric dog polisher.
    -Noel
    May 21, 2012 7:57 AM   in reply to adobe-admin
    I just noticed that there are several useless hacks for IE6 users in this forum template. You could save yourself a lot of trouble by moving on and focusing on fixing quirks using only modern browser targets. Removing this old IE6 code will improve delivery for everyone.
    IE6 is used by people stuck on Windows 98. The only market that still uses IE6 is in Asia, where piracy is rampant and users do not need to 'activate' Windows 98. (Activation was introduced with XP).  As Adobe provides neither products nor support for Windows 98 users, it makes no sense to be bothering with IE6 compatibility here.
    IE6 usage data: http://www.ie6countdown.com/
    IE7 usage is comparable to IE6. You really only need to design for IE8 and above.
    http://gs.statcounter.com/#browser_version-ww-monthly-201104-201204
    May 21, 2012 3:18 PM   in reply to Noel Carboni
    Thanks, Noel, for giving them a name. However, regardless of their name and what they are there for, why do I see them in only a few messages? Now that I know what they are, I remember that before this last change we had a list of tags at the end of every (?) message.
    May 21, 2012 7:53 PM   in reply to Noel Carboni
    I believe they are an important part of the Search engine.  (Or is it ask-a-question engine now?)
    May 22, 2012 7:51 AM   in reply to Claudio González
    I wonder whether they are invoked when someone ticks something, ghosts waiting to haunt us when woken.
  • Noel Carboni
    Dec 23, 2006
    May 22, 2012 9:38 AM   in reply to Claudio González
    Create a new thread.  You have a field for entering tags.  Some people fill that field in and some don't.
    -Noel
    May 23, 2012 2:13 PM   in reply to adobe-admin
    I cannot remember its being mentioned:
    You can no longer use Back to [relevant forum name] to return to the place/page in the forum thread list that you came for. The Adobe Forums > ... > [relevant forum name] > Discussions link takes you back to the start ogf the list.
    Funny, but not funny hah hah, when you are on one of the other pages.
    The only way to get back is clicking the browser Back button, in most cases twice because the first time gets you nowhere else, as reported and discussed here and elsewhere.
    May 23, 2012 4:52 PM   in reply to Jacob Bugge
    Thanks, Jacob. I'll add it to the list, for what that's worth. Still trying to fight to get more things back.
  • Noel Carboni
    Dec 23, 2006
    May 23, 2012 6:02 PM   in reply to Jacob Bugge
    Jacob, I'm not seeing problems with the Back key, but chances are I'm not using like you are.
    Can you be just a little more specific about just what to click to reproduce what you're seeing?  I tried just clicking on forum posts, then clicking links within.  The Back arrow in IE9 always seems to return me to the place I was before.  I just want to make sure I'm doing exactly what you're doing.
    -Noel
Actions
