Flash Installation Per System
May 11, 2012 9:16 AM
Tags: #install #flash_player #64bit #flashplayer #flash_player_11
We're trying to understand our options with installing Flash onto our Windows 7 systems. We normally take the .msi installer and import that into our software deployment server (Microsoft SCCM). We've been deploying Flash with SCCM and using the Per-system unattended option using this command
msiexec.exe /q ALLUSERS=2 /m MSIXJSCK /i "install_flash_player_11_active_x_64bit.msi"
I recently read an article that said you shouldn't install Flash for ALLUSERs or per system. It should be installed per user instead. This seems to make sense from what we're now seeing. Users are calling us saying they need to install Flash when they hit a web site that needs it. We look and see that Flash was already installed with the above command line.
Should we only deploy Flash per user and not per system?
    May 11, 2012 8:54 PM   in reply to Sandy_ocda
    I don't know about that; where did you read it?
    See the Flash Player Admin Guide at http://www.adobe.com/devnet/flashplayer/articles/flash_player_admin_gu ide.html
    May 14, 2012 7:29 PM   in reply to Sandy_ocda
    I am not an expert on Flash Player deployment; hopefully someone from the Adobe team can step in here.
    Meanwhile can you list what files you have in
    • C:\Windows\system32\Macromed\Flash ?
    • C:\Windows\syswow64\Macromed\Flash ?
    • the contents of the FlashInstall.log files from both above folders.
    What browser(s) do your users use?
  • Chris Campbell
    May 4, 2010
    May 15, 2012 6:40 PM   in reply to Sandy_ocda
    I've forwarded this to the installer team for their review
  • Chris Campbell
    May 4, 2010
    May 18, 2012 3:14 PM   in reply to Sandy_ocda
    Here's what I heard back:
    While running the MSI installer as a per-user install should work, it would require that the user (or process) that launches the MSI have Admin privileges (or enter Admin creds at install time).
    Also, despite how the Flash Player installer is launched, it will only actually be installed on a per-system basis (we only install to the system directory as opposed to a user-specific location).
    Let me know if this doesn't help.
