Dear All,
I create a form with multi text fields and multi image fields. Each text field contains the full path name of related image file. Is it possible to write a routine in form to automatically attach image files into respective image fields. This function should be automattically activated when opening PDF.
It will be appreciated if someone has similar codes can be shared.
Jackson
Please try. Hope this helps.
On the Accessibility tab type in the tooltip field the path of the image and you can use "Image1.assist.toolTip.value" to get the value.
- Also on form: ready of the image use "Image1.value.image.href = Image1.assist.toolTip.value;" where the tooltip is set to the path of the image.
Deepak
Hi Deepak,
Thanks for the reply. I've tried the following, but it didn't work.
1. I created a new form in LiveCycle Designer ES2
2. Insert a text field and an image file
3. Set the text field default to image path (C:\Users\jackson.chen\Pictures\2011-03-12\002.JPG)
4. Click Image file, and select Form:Ready* in Script Editor
5. Enter script : ImageField1.value.image.href = TextField1.rawValue ;
6. Save the PDF
The image field still get nothing displayed. I tried to use Imagefield1.assist.toolTip.value, but it displays nothing either.
Please let me know where I've missed.
Jackson
Jackson,
I have created a sample form for you. Could you please check, and let me know is this what you are looking for ?
https://acrobat.com/#d=NRF3GhyC6KqBS6mDZhKOvQ
Hi Deepad,
Thanks for your sample image.pdf.
For unknown reason, I cannot still see the image in your PDF. I can see the LC logo if I paste the http link to IE. Is there something to do with From Properties?
I've created a imagetest.pdf which has one text field and one image field. Please take a look, but the image can not be displayed either.
My image file is not in http but right in c drive.
ftp.bentley.com/pub/outgoing/Imagetest.pdf
Appreciated your help.
Jackson
Jackson,
I investigated more about this issue.Here's what I would like to say.
In the case of a dynamic document, all href's are removed and replaced with the actual base64 encoded data, embedded into the xdp. This is done so that the image will be available at runtime Acrobat when regenerate the document. If we left it as an href, one wouldn't be able to view the document online, and even if you were online, one could run into trust manager issues, by trying to fetch a link that was not trusted. This is as designed. If you open the document in designer, you will notice there is no longer an href, and if you view the source, you will see the embedded data in it's place.
Hi Deepad,
I' don't think I understand these href, xdp and dynamic form, etc.
My intention is to manually enter an image path in text field, and have image field to get this path and display the image. Also, when this PDF saved and send to someone else, he can still view this image without having this physical image file.
Is there a easy way we can do this either in LiveCycle Designer or Adobe pro? Can we use static form?
Thanks for thelp
