Mavizion
missing image on submitted form
May 15, 2012 9:40 PM
Tags: #missing #on #image #submitted #pdf_fillable_forms;
Hi All,
I am goining to use pdf form for my own topic survey,
I had distributed a pdf survey form for test , it contained  a button field for user to attach his own image.
I had tried to fill it on acrobat pro 9, and it was success to submit(including the user-attached image).
but when i check back the filled response form,
i found that the image ( added in button field, filled by user ) was missing,
do i missing something or anything wrong on my source files?
my javascript source
var f = this.getField("myPBIcon5-3");
f.buttonPosition=position.iconOnly
f.buttonImportIcon();
Albert
  • George Johnson
    Aug 11, 2002
    May 15, 2012 10:17 PM   in reply to Mavizion
    Note that the buttonImportIcon method does not work with Reader, so if that's what your users are using, you're out of luck. If you're like to see it work with Reader some day, please post a feature request, or you can add your voice to this existing one: http://forums.adobe.com/thread/743823
  • George Johnson
    Aug 11, 2002
    May 16, 2012 12:10 AM   in reply to Mavizion
    Is this a form that you distributed so that the entire PDF is being submitted, or did you set up the form to submit just the form data?
