how to access indesign cs3 document through VC++
May 5, 2008 8:34 PM
Hello
am new to VC++, i need to communiacte Indesign CS3 through VC++, for this what can i do? inorder to access indesign docuemnts,
also need to access a Third party API for CS3 through VC++, for the two puproses, i dont have any idea, so
kindly help me
with regards,
ram
    Apr 14, 2009 10:47 PM   in reply to (ramanathan.ct)
    Hi Ramanathan,
    If you have the solution to access the third party plugin (Inmath styles) in indesign using VC++, Please help me.
    Saravanan Rethinam
    May 16, 2012 1:55 AM   in reply to (ramanathan.ct)
    Hi Ramanathan
    http://forums.adobe.com/message/4407895#4407895#4407895
    I read at above link  that you accessed the Indesign through VC++ with  the help of  code
    give by Bo_Peters. Plz tell me How access InDesign  through VC++.
    I am able to develop application in C# using COM and generate Interop.Indesign.dll using Adobe Indesign CS5.5 Type Library
    I am sucessfully create Indesign instance using this code in C#
    Type type = Type.GetTypeFromProgID("InDesign.Application");
    InDesign._Application application = (InDesign._Application)Activator.CreateInstance(type);
    I am not understand how use COM with vc++ or there is another method to create Indesign instance using vc++.
    or
    How use Interop.Indesign.dll in vc++ to create indesign instance.
    I want to create Indesign in vc++.
