CSS flyout Menu Help!
May 16, 2012 8:37 AM
I'm having a problem with my CSS flyout menu. Everything works great, but the links only work if I right click and open in new window. Any ideas?
PS: I don't have overflow hidden
  • Sudarshan Thiagarajan
    Oct 15, 2010
    May 16, 2012 10:28 AM   in reply to John Delamotte
    Post a link to your active page on the web. Also, let us know which browser you're using so we could test it here.
    May 19, 2012 12:37 PM   in reply to John Delamotte
    Maybe this tutorial will help you.
    http://alt-web.com/DEMOS/CSS-Horiz-menu-3.shtml
    Nancy O.
    Alt-Web Design & Publishing
    Web | Graphics | Print | Media  Specialists
    http://alt-web.com/
    May 19, 2012 2:45 PM   in reply to John Delamotte
    What's the URL so we can see for ourselves what happens.
    Menu won't work if you don't add pages to your links. <a href="#"> is a null link that goes nowhere.
    Also, get rid of target="_self" you don't need it.
    Nancy O.
    May 20, 2012 9:45 AM   in reply to John Delamotte
    John Delamotte wrote:
    The problem is that the links don't work right. They only work when you right click, open in new window or tab. What I am I doing wrong?
    No way to answer this without seeing your page.  Please post a URL.
    Nancy O.
    May 16, 2013 10:14 AM   in reply to John Delamotte
    John,
    I am having this same issue. How did you fix this!
    Thanks in advance.
    Enric
    May 16, 2013 3:09 PM   in reply to edg13
    What is the URL to your problem page?  Answers to questions like these are contained in your code.
    Nancy O.
    May 17, 2013 9:55 AM   in reply to Nancy O.
    Hey,
    fluentroad.com
    You will have to create a free trial. Verify via email and click on the help button when you are logged in!
    Much appreciated.
    May 17, 2013 2:35 PM   in reply to edg13
    You've got to make it simple for us to see your problem page with one click to your site.  The best way to do that is upload your problem page to a TEST folder on your server.  Post the relevant URL here.  When your question has been answered, delete the TEST page & folder from your server.
    If your home page is any indication of the rest of your site, you have a significant number of code errors that need attention.
    http://validator.w3.org/check?verbose=1&uri=http%3A%2F%2Ffluentroad.co m%2F
    Most linking issues are caused by simple code errors or bad paths from pages in sub-folders to the site root.  Also, Apache/Linux servers, are cAsE sEnSiTiVe.   So a file named AboutUs.html is not the same as aboutus.html
    Nancy O.
    May 17, 2013 2:46 PM   in reply to Nancy O.
    Hello Nancy,
    So I was just trying to facilitate the fix for our developers that are busy enough already. Thanks for pointing out those errors on the home page.
    At this point I will just redirect one of the developers to handle this. I will go ahead and check for the case sensitive issue.
    Thanks again.
    Enric
