How to share/send a .folio file for another designer to open and work on?
May 16, 2012 11:34 AM
what are the simple steps here? We both will be using CS5.5 and both using V19.
thanks in advance
Tom
  • Bob Bringhurst
    May 29, 2007
    May 16, 2012 11:46 AM   in reply to tom d. design
    You can't share and edit .folio files. Instead, you need to send the source files to the other designer, and that designer needs to relink to (or re-create) the articles in the folio. Make sure that you include all the overlay files. The recipient should check overlays to make sure they're still connected in the Overlays panel. A yellow triangle appears in the panel if an overlay is disconnected.
  • Bob Bringhurst
    May 29, 2007
    May 17, 2012 9:59 AM   in reply to tom d. design
    Yes. Either re-create the folio using the import multiple/sidecar.xml method, or use the Relink option in the panel.
    Again, the key is to make sure that all the file are transferred properly and overlay assets relinked if necessary. In ID CS6, there is better support for packaging and linking overlay assets.
    May 17, 2012 10:19 AM   in reply to tom d. design
    May I suggest putting everything into a Dropbox folder and sharing that. This will ensure that both of you have the same assests.
    When the other person is done, you can simply relink the articles with no need to transfer files back and forth.
    And yes, I know for a fact this works since I do it myself.
    Bob
    May 18, 2012 8:54 AM   in reply to Bob Bringhurst
    Out of curiosity, would the Creative Cloud support the workflow in question?
    http://www.adobe.com/products/creativecloud/store-and-share.html
    Nate_
